FS:: 2003 Cooper S New Engine New Clutch
Old Jun 13, 2019 | 08:09 AM
dhabutcher's Avatar
dhabutcher
Year: 2003
Model: Coupe
Price: $6800
Mileage: 123000
Color: Electric Blue
Location (Region): Midwestern
[size=3]I found this car listed with a bad engine, And had been in storage 2 to 3 years.[/size]
[size=3]Started building the car for my Niece, She got a new car before I got this on done....[/size]
[size=3]So here it is for sale [/size]
[size=3]Super Clean / New Engine / New Clutch / New Suspension[/size]
[size=3]If you bough a 3500.00 MINI you could not install a engine, clutch or most of this work for less than listed price of this car done[/size]
[size=3]All work done by myself, ASE Master Auto Mechanic. ASE Master Auto body collision Technician. GM Certified Technician [/size]
Engine
Block Decked / bored
[font=Arial]New pistons / rings[/font]
New Oil Pump / Pump Pick Up
New timing chain, cam & crank gears, Tensioner and Chain guides
[font=Arial]New main and rod bearings[/font]
Head Milled.
Valve guides replaced and New Valve Stem Seals
[font=Arial]Stainless Steel Exhaust manifold studs[/font]
Stainless Steel Intake manifold studs
2006 Mini Engine Crank Pulley / Dampener
Cooling System
New Water Pump
New Aluminum Thermostat housing and Thermostat
Engine Belt Tensioner
Engine Belt Gates K060547RB Blue Racing
Engine Belt Idler Pulley
New Aluminum Coolant expansion tank and Cap
Transmission
Factory Mini Locking differential
Valeo Clutch Kit Single Mass Flywheel / Clutch / Pressure plate / Release bearing
New Clutch Slave Cylinder
New Front Complete CV Axle Shaft Assembly Right and Left
New Fluid
Fuel System
New Siemens VDO Fuel Pump and Filter
380CC JCW Injectors
Supercharger Bypass Valve
Exhaust
Pace Setter Header / Convertor
JCW Mufflers and Tips
Suspension
Stainless Steel Strut Reinforcement plates
MONROE 906983 Left and Right Strut Turn Plates
Front and Rear Bilstein B4 OEM Struts
Right and Left Rear Wheel Bearings
Super Pro Front LCA - SPF2550K. Rear A Arm Bushing & Caster Kit
Right and Left Lower Outer Ball Joints
Right and Left Lower Inner Ball joints
Power Flex Rack Bushing
Power Flex Sway bar Bushings Front and Rear
New Rear Lower Adjustable Control Arms
Steering
New Power Steering Lines
[font=Arial]New Power Steering Cooling Fan[/font]
[font=Arial]New Inner Tie Rod[/font]
[font=Arial]New Inner Tie Rod / Rack Boots[/font]
[font=Arial]New Outer Tie Rod[/font]
[font=Arial]4 Wheel Alignment [/font]
Brakes
2007 R56 Front Calipers
New front brake lines to install 2007 R56 Calipers
New drilled and slotted Front and Rear rotors
New brake pads front and rear
Brake Fluid flushed and New fluid
Tires & Wheels
[font=Arial]New Federal Formoza AZ01 Run flats On 2009 MINI Factory Wheels[/font]
[font=Arial]Interior [/font]
[font=Arial]Recovered Head Liner[/font]
[font=Arial]Leather Shifter and Park Brake Boot[/font]
[font=Arial]Extras[/font]
[font=Arial]New MINI fog lamps / With auxiliary switch[/font]
[font=Arial]MINI Factory Car Cover [/font]
[font=Arial]New 810 CCA Battery from Advanced Auto Parts with Warranty[/font]
[font=Arial]Rebuilt O'reilly auto parts Alternator [/font]
[font=Arial]Buffed Head Lamps[/font]
Attached Thumbnails 2003 Cooper S New Engine New Clutch-img_20190527_142237.jpg   2003 Cooper S New Engine New Clutch-img_20190527_142206.jpg   2003 Cooper S New Engine New Clutch-img_20180420_223641.jpg
Last edited by dhabutcher; Jun 13, 2019 at 10:22 PM. Reason: Adding photos, typo in mileage
Old Jun 14, 2019 | 11:20 AM
bahman's Avatar
bahman
This is a great value. Too bad I already have 3 R53s; otherwise, I'd already bought it. It's basically as-new mechanically.
Old Jul 15, 2019 | 12:10 PM
rad63's Avatar
rad63
Is this one still available?
carguypat
Dec 17, 2018 07:42 PM
jrswun
Jan 23, 2016 10:00 AM
SavageTyler
Jun 12, 2014 12:16 PM
andrewjg1994
Mar 28, 2012 03:02 AM
DreamMini
Oct 15, 2011 11:55 PM
