2008 Mini S boost solenoid
Old Jun 10, 2019 | 06:55 PM
AW135751's Avatar
AW135751
Bought this mini a week ago. 117K . No boost at first . Reduced power half yellow engine light plus P 1497 codes . Found a cracked valve cover . Replaced the valve cover . Found pcv line cracked in many places . Fixed pcv line. Ran a smoke test and the only thing that smoked a little was the boost solenoid. Tied the 2 vacuum lines together and I had boost for the first time but seems like the wastegate would open up and dump randomly. Replaced boost solenoid and put lines back and no boost . Getting the p1497 code and a P0420 code . I also put on a new diverter valve today also. HELP APPRECIATED !!!
Old Jun 11, 2019 | 12:46 PM
oldbrokenwind's Avatar
oldbrokenwind
Are you sure the smoke was coming from the solenoid? There's a plastic tank in the same area, and if it leaks you could have the same problem. Also, double check the vacuum hoses --- they soften easily.
Old Jun 11, 2019 | 12:56 PM
AW135751's Avatar
AW135751
The factory solenoid had a metal ring that looked to be crimped and the smoke was coming from there. Just trying to figure out why the computer isn’t telling the solenoid to open up . When I bypass that solenoid the turbo works . New solenoid didn’t fix the problem. Keep getting a catalytic converter code so trying that next
AW135751
Jun 11, 2020 06:00 AM
MrGrumpy
May 30, 2019 01:23 PM
Zommski
Jun 19, 2018 08:50 AM
Price
Feb 23, 2017 01:44 PM
