Suspension Self-Locking Bolts - huh?
Old Jun 9, 2019 | 05:15 PM
JAB 67's Avatar
JAB 67
Last year I replaced the original rear strut assemblies in my 2004 R53 with almost 160K. I reused the bolts that secure the rear strut mount to the strut tower. Recently I read that the "self-locking bolts" should be replaced. Why do they call them 'self-locking' and why should they be replaced with new?
Old Jun 9, 2019 | 05:54 PM
cooper48's Avatar
cooper48
"Self-locking" is a bit of a misnomer. That indicates an inner thread coating on the nut that prevents it from spontaneously reversing once installed. I doubt you'll have a problem even though you reused the existing nuts (coating will deteriorate over time). Replace them if it bothers you since they're easily accessed.
Old Jun 9, 2019 | 11:10 PM
JAB 67's Avatar
JAB 67
I am confused. I am fairly certain that what holds the mount to the strut tower is a bolt that engages a captive nut.
Old Jun 9, 2019 | 11:24 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
BMW MINI has certain bolts with encapsulated blue "loctite" type of thread locker which activates on use. Instead of spending $35 on the bolts that secure the seats to my car, I just put some loctite on each bolt before re installation. They sure do look for ways to separate owners from our money.
Old Jun 10, 2019 | 02:26 PM
Anakist's Avatar
Anakist
If it is the ones I am thinking about those particular ones are triangle shaped, and cut and form new threads as they are screwed in. Not sure why they want you to replace them. Maybe they wear as they form and don't bite in as hard if reused.
If you are going to be changing things regularly, go buy some normal M14 bolts and Loctite them in. Then you don't have to worry about messing up the thread in the arm.
James
Old Jun 10, 2019 | 05:03 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
James
You must be referring to the later R52 or R56 with the aluminum trailing arms. Most gen 1 has steel arms and no self cutting bolt threads.
Old Jun 11, 2019 | 02:05 AM
Anakist's Avatar
Anakist
My 2004 R53 had steel arms and lobed bolts.
James
phlaug
11
Jul 16, 2019 04:16 AM
orangecrush
Sep 8, 2010 10:29 AM
mrgentleminh
12
Aug 18, 2007 09:45 PM
rc'S
25
Aug 13, 2007 03:05 AM
jimmy330
Sep 6, 2006 08:30 PM
