Clutch and flywheel
Old Jun 8, 2019 | 02:29 PM
Parker Young's Avatar
Parker Young
Clutch and flywheel
Ok hey everyone I'm in search of a new clutch and am not sure what to chose. I am deciding between clutch masters or south Bend Clutch. I currently have a stock 2007 mini cooper s. I have plans to upgrade my car after the clutch is done, my goal is 200 whp.
I know for sure that I want a single mass flywheel to handle extra power but specifically a steel one not aluminum so there is as little chatter and gear noise as possible.
Do all three brands I'm looking at have single mass steel flywheels? Which brand and stage would be best for me?
Thank
Parker
Old Jun 9, 2019 | 05:46 AM
I like mini clubman's's Avatar
200 whp is an easy goal. The stock clutch will handle that extra bit of hp easy. I've got 200 whp with a new $150 LUK clutch and I do not experience any clutch slippage. Tires yes, clutch no.
Old Jun 9, 2019 | 12:03 PM
oldbrokenwind's Avatar
oldbrokenwind
Do the other upgrades first and wait for the clutch to start slipping. By then, you should have more info on which clutch will be best for you --- and you'll probably have higher goals too, power is addictive.
Old Jun 9, 2019 | 05:20 PM
Parker Young
I need a new clutch very soon. It slips in 3rd and above once boost hits. 200whp is just my starting goal with bolts on's and stock turbo. I know I want either a South Bend or clutch master clutch and flywheel. Southbend is a bit cheaper but have heard great things about the brand just not anything mini experience wise.
Old Jun 9, 2019 | 05:23 PM
Parker Young
I assume you still converted to a SMF. I know I don't want a DMF because with more power and torque it won't last. I also might as well put a better clutch in it too than OEM to support whatever the future brings
Old Jun 9, 2019 | 06:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Go with the clutchmaster like the FX250 as it will work for that.
https://www.waymotorworks.com/clutch...-cooper-s.html
Old Jun 9, 2019 | 06:37 PM
oldbrokenwind
If you can find the $$$, go for an OS Giken STR series clutch / flywheel package. Minimum chatter with aluminum and very reliable, even when handling 300+ WHP and 400ft-lbs torque.
Parker Young
Do you have any input on southbend?
Old Jun 9, 2019 | 06:39 PM
Parker Young
Ya I thought about that buys its just so expensive. I don't want to pay that much
Old Jun 9, 2019 | 07:08 PM
Parker Young
According to Car ID the price for southbend stage 2 clutch with flywheel is $1200 CAD.
Clutchmasters FX250 and steel flywheel is $1600 CAD
What I can't figure out is the weight of each flywheel. If one is heavier I want to go with that one to reduce any gear noise.
Old Jun 10, 2019 | 06:40 AM
I'm running the factory DMF and cheapest clutch on rockauto.com. if anything I need a posi to get traction to both wheels.
Old Jun 10, 2019 | 05:46 PM
Parker Young
Ok so update apperently the southbend comes with a dual mass flywheel. This is weird to me because with everything I have read, I understand that a dual mass flywheel is not able to handle any power increases and will break very quickly.
Old Jun 12, 2019 | 05:05 PM
WayMotorWorks
Vendor
We offer the South Bend kits and have had very good luck with them. But they just are a clutch, pressure plate, and throwout bearing. You mount this kit to your existing Dual mass flywheel.
https://www.waymotorworks.com/south-...7-r58-r59.html
Old Jun 12, 2019 | 08:49 PM
mellocooper's Avatar
mellocooper
I have a SB stage 2 in my otherwise stock 2013 GTI. Pedal is a little heavier than I like but perfectly livable. It has a very nice confident feel to it. In fact it really transformed the car.
Old Jun 13, 2019 | 01:59 PM
Parker Young
I need a new flywheel as well. If I replace the dual mass flywheel with another dual mass, won't it not be able to withstand power and torque increases?
Old Jun 14, 2019 | 11:27 AM
WayMotorWorks
Vendor
Yes you can replace the dual mass with another new one. The stock flywheel can handle the power so I wouldn't be concerned with that.
https://www.waymotorworks.com/stock-...-cooper-s.html
Old Jun 14, 2019 | 08:52 PM
Parker Young
How much torque and power can the dual mass handle. Everything that I've read has said the stock one can't handle any increase and will fail even if you just drive your car hard.
Old Jun 25, 2019 | 08:33 PM
WayMotorWorks
Vendor
We've had customers put 250hp to them without failure.
Old Jun 25, 2019 | 09:00 PM
Parker Young
Ok but more importantly how much torque and did they still last just as long?
Old Jun 26, 2019 | 01:13 PM
WayMotorWorks
Vendor
Never seen or heard of the stock flywheel failing from "too much" HP.
Normally they fail with age. And usually it's just a spring inside of it that breaks, they don't like fall apart. The clutch will give up before the flywheel.
Indimanic
Oct 6, 2017 05:56 AM
MiniMoMir
Jan 14, 2008 02:12 PM
