TMAP vs MAF sensors
Old Jun 8, 2019 | 12:47 PM
PeteP's Avatar
PeteP
TMAP vs MAF sensors
I was wondering if the TMAP & MAF sensors were interchangeable, for T-Shooting purposes.
PN's are
12140872648
12140872679
If anyone can answer this please mail me
petepees@bellsouth.net
Old Jun 8, 2019 | 01:04 PM
A383Wing's Avatar
A383Wing
No, they are not.....the sensors will mount in either spot....but they are different sensors.....also, the Map sensor has 4 terminals inside, the T-MAP sensor only has 3
Bryan
Old Jun 9, 2019 | 10:56 AM
PeteP's Avatar
PeteP
Thanks for the input. I am struggling with the dreaded P2096 once again and thought I was gonna have to replace one of those sensors.
I took them both out and cleaned them, had a new O2 sensor installed in the rear position and checked as best I could for vacuum leaks.
From what I can see, this code should clear but it is not. I have reset it several times, let the car run thru the emission checks and everything is good, why won't this code clear??
it comes on immediately when i start the car too, I would think that it would need to run a while before it could code out again.Any ideas??
Old Jun 9, 2019 | 11:03 AM
A383Wing's Avatar
A383Wing
just curious, how & what are you using to try and clear the code with??
Bryan
Old Jun 9, 2019 | 12:20 PM
PeteP's Avatar
PeteP
BlueDriver & Torque
Old Jun 9, 2019 | 12:47 PM
A383Wing's Avatar
A383Wing
A lot of aftermarket scanners, code readers, and Bluetooth devices will not clear codes on European vehicles. I have a Snap On scanner which is updated to the latest software version, I couldn't get it to clear codes on my '04 R53.... I ended up getting a Schwaben scanner from ECS tuning..... that one works
Bryan
ragingMINI
Feb 16, 2016 11:22 AM
silence2-38554
Dec 12, 2015 06:33 PM
Wakey05MCS
Sep 5, 2011 06:31 AM
BlimeyCabrio
Electrical
Nov 23, 2009 11:29 AM
markldriskill
Oct 30, 2008 10:59 AM
