Vibration in the gas peddle
Old Dec 2, 2004 | 08:38 AM
Pebblecrusher's Avatar
Pebblecrusher
Will sound silly, but I am not sure my MINI has always done this. But there is a fairly strong vibration in my gas peddle, especially at cruising speeds (6th gear around 70-75 MPH). I feel it at other speeds as well, but mainly while at a constant speed.
The only major things I've done are the short shift kit and the 15% pulley. If the pulley/belt were slightly off center, could this cause my problem? What other things could cause it? I know it's a broad question, but hopefully something will come of it.
Old Dec 2, 2004 | 08:55 AM
mcowger's Avatar
mcowger
THats very strange, because the MCS has a thorttle by wire - no thorttle cable...
Old Dec 2, 2004 | 09:05 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
More than likely you might have something like the exhaust hitting the floor in the area near the pedal. Since there is no mechanical connection to the pedal, this would be the only plausible explanation. You might also have a loose engine mount near that area too.
Old Dec 2, 2004 | 03:42 PM
Pebblecrusher
Hmm, engine mount loose. The lower engine mount did have to come undone for the pulley install. I'll have to get under there and see if I can find it.
Old Dec 2, 2004 | 07:01 PM
welshmenwillnotyield's Avatar
Remember, too, that you DID hit something back in October that wreaked havoc with your front end. Maybe it affected something underneath as well.
Old Dec 2, 2004 | 08:17 PM
Ryephile's Avatar
Ryephile
naw - my MINI does this too, albiet only marginally. No broken anything, just a funky resonance mode. Usually at highway cruising speed, depends on the pavement texture, and especially what tire I have on. I chalk it up to the nature of the beast.
Old Dec 2, 2004 | 08:29 PM
bigpmj's Avatar
bigpmj
Yeah, mine does the same thing.
Old Dec 2, 2004 | 11:04 PM
lotsie's Avatar
lotsie
My right foot feels a vib,when cruising at 3000RPM.I tend to have to speed up and down a lot,so it goes away.But there is a buzz in my right foot at times.
Old Dec 3, 2004 | 05:39 AM
Pebblecrusher
Welsh - It did it before the exhaust pipe incident, but a good thought.
Thanks for the warm fuzzy. I was curious if others felt the buzz as well.
Old Dec 3, 2004 | 02:47 PM
pdflint's Avatar
pdflint
I also feel a slight vibration in my box stock '04 MCS, except that I can also feel it it the clutch and the steering wheel. It seems to be most prevelent when I am coasting (slogging through Chicago rush hour traffic). I first thought it was a combination of the tires (Goodyear 17" Runflats) and the pavement, but I'm wondering if its something in the drivetrain. The amount of vibration I feel is not objectionable, however, if somethings going wrong, I want to fix it before it gets worse. I have only driven one other MCS (original test drive), so I don't have any reference if this is normal. Any feedback would be appreciated.
scfiveo
Sep 27, 2019 02:27 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
minieater
Oct 28, 2015 02:15 PM
donniedarko
Oct 21, 2015 01:15 PM
