2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 How does Active Sound Design work?
Old May 27, 2019 | 11:22 AM
creep's Avatar
creep
Is the ASD on all the time or just when using sport mode?
I have a new manual transmission S All4 and can't tell if ASD is in use when I step on the gas or if it's the normal engine sound.
Old May 27, 2019 | 12:18 PM
F56-JCDub's Avatar
F56-JCDub
It seems that ASD is on by default during Normal, and Sport. It doesn't seem on in Green mode.
Old May 27, 2019 | 12:24 PM
BTDUBS's Avatar
BTDUBS
Is there any way to turn it off? Having that on with the JCW exhaust kinda hurts it a bit.
Old May 27, 2019 | 12:51 PM
creep's Avatar
creep
Thanks f60jcw. So if I enable green mode would that be the standard engine sound?
Old May 27, 2019 | 03:22 PM
F56-JCDub's Avatar
F56-JCDub
You need a bluetooth obdii adapter and Bimmercode to disable it.
Old May 27, 2019 | 03:24 PM
F56-JCDub's Avatar
F56-JCDub
Well the modes also change other engine characteristics like timing, fuel, etc. I don't know the specifics, but just observed that ASD is off in green.
Old May 28, 2019 | 09:02 AM
JDWatts's Avatar
JDWatts
When using a JB4, there is an option to disable it in their main menus. Kind of a nifty surprise.
Old May 30, 2019 | 03:35 PM
ASKtheteach's Avatar
ASKtheteach
Sport Mode does not in any way impact the timing of the engine, fuel delivery, etc. When activated, it tightens the steering, stiffens the suspension (if the car is equipped with Dynamic Damper Control), adjusts the transmission shift points (if the car is an auto), and enables the “pops and burbles” from the exhaust. Those occur because it is a direct injection engine, and it overfuels the cylinders to cool them when in Sport Mode. The pops and burbles are the burning off of the excess fuel.
Old May 30, 2019 | 03:38 PM
F56-JCDub's Avatar
F56-JCDub
What about Green mode? There's definitely something going on with the engine there, not just the transmission.
Old May 31, 2019 | 07:05 AM
JDWatts's Avatar
JDWatts
The electronic throttle pedal position vs throttle body opening is mapped differently for each of the 3 modes.
Sport - mapped to more aggressively open the throttle body relative to throttle pedal position.
Normal - nominal throttle pedal/throttle body mapping
Green - opens the throttle body less aggressively for better fuel consumption and that lazy feeling throttle response.
Old Jun 23, 2019 | 08:07 AM
Brookz's Avatar
Brookz
Do you have a recommendation on what bluetooth obdii works best?
Old Jun 23, 2019 | 08:30 AM
F56-JCDub's Avatar
F56-JCDub
This one worked for me:
Amazon Amazon
Old Jun 23, 2019 | 08:46 AM
Brookz's Avatar
Brookz
Thank you!
Old Jun 23, 2019 | 10:19 AM
Brookz's Avatar
Brookz
https://www.amazon.com/dp/B06XJJGSGT
This is WiFi and not Bluetooth based?
Old Jun 23, 2019 | 10:40 AM
bluonyx's Avatar
bluonyx
Same one that I use, get the Wifi one it's faster.
Old Jun 23, 2019 | 11:09 AM
F56-JCDub's Avatar
F56-JCDub
Yes WIFI is better than BT.
GregoryK
Jun 13, 2021 12:23 PM
sdupp
Navigation/Audio
Oct 15, 2018 07:35 AM
tylerhunter
Navigation and Audio
Apr 22, 2017 07:40 PM
GregoryK
May 8, 2015 04:18 PM
tripleTurbo
Aug 30, 2014 11:01 AM
