R56 Aux Tensioner Modification
Old May 26, 2019 | 02:07 AM
stevie01's Avatar
stevie01
Old May 26, 2019 | 10:32 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Interesting! Tell us more.
Old May 28, 2019 | 07:42 AM
Yupetc's Avatar
Yupetc
What's wrong with the factory tensioner? I don't get this at all. Besides, just by looking at it, does it mean I'll need to remove those 3 bolts each time I want to change a belt? Oh wait, there's more, it took out the friction pulley. I see where this is going, but then again, it looks like a pain in the butt to get the belt out, and there's no tensioning. Everything looks fixed, can you imagine how hard it would be to work with the belt with no slack room?
Old May 29, 2019 | 09:04 PM
squawSkiBum
Moderator
You're forgetting about the tensioner that is next to the alternator. This gets rid of the friction wheel by the water pump, so changing the belt should be just as easy.
The question I have is those small diameter wheels will be spinning really fast, does that cause a problem with bearing life?
Old May 30, 2019 | 03:19 AM
stevie01's Avatar
stevie01
hi the bearings are SKF rated at 20,000 RPM with axial load stiffness ,which doing the pulley size maths would be 7000 RPM more than capable thanks for your interest
SD
Old May 30, 2019 | 07:23 AM
squawSkiBum
Moderator
Does that use stock holes in the block, or did you have to add them? Thinking about it a bit more at least one of the pulleys would have to be removed to change the belt. Not terrible since the belt is a 60K service interval, on my other car one of the motor mounts has to be removed to change the accessory drive and timing belts.
Old May 30, 2019 | 08:39 AM
stevie01's Avatar
stevie01
the stock three holes,keeps belt alinement simple
Old May 30, 2019 | 10:16 AM
Andy_S's Avatar
Andy_S
SD
Isn't that pulley running about 5x crank speed, so 32,500 RPM at 6500 engine RPM?
Old May 30, 2019 | 12:39 PM
stevie01's Avatar
stevie01
no !
Old May 31, 2019 | 08:23 AM
Andy_S's Avatar
Andy_S
no !
My bad. I assumed the pulley at the bottom of the photo was the crank pulley.
JaysinStrife
Jul 17, 2015 01:03 AM
crazyworld
Nov 20, 2014 07:04 PM
VII
May 26, 2014 03:27 PM
daonlyillwiz
Feb 4, 2014 06:28 PM
