Update on mysterious cold start rough idle
Old May 20, 2019 | 09:39 PM
Uberschprung's Avatar
Uberschprung
I purchased the timing tool for my N12 once I discovered I only 2 in of vacuum. Hoping this was related to the cold start rough idle I decided to verify my timing. Once the crank pin is in and the halves of the cam holders are tightened, there is clearly a gap between them. The screw to lock the halves together won’t start unless the halves are loosened—and even then the intake cam lock pulls/warps downward to become flush with the exhaust.
It appears i am I am out of time—would you agree?
Exhaust jig tightend
I take jig tightend
Gape between the halves when tightened
Gap when halves are tightened. Bolt will not start u less they are loosened
Old May 20, 2019 | 09:42 PM
Uberschprung
Here is a video once the Cyrene bolt is tightened then loosened—you can see the stress it’s putting on it to have it tightened
Old May 21, 2019 | 12:07 AM
Scudder44's Avatar
Scudder44
You are in that place where it is time to replace the timing chain, guide rails, lower sprocket and if you have very high mileage maybe worth doing the oil pump chain at the same time. There are loads of guides of how to on Youtube. Chains kits are available and one post recently pointed in the direction of a good kit in the UK (if that's where you are) from Neo Brothers.
Replacing the front crank shaft seal is also part of this routine. While you are in that area consider the age of the water pump and if it is still the black plastic one, get the newer uprated metal one. Auxilliary belt too.
fixthedoor
R55 :: Clubman Talk (2008+)
Sep 14, 2016 07:03 AM
wolfe
Sep 4, 2012 04:49 AM
Kwasi-moto
Dec 27, 2011 02:34 AM
Ted Stevenson
Apr 2, 2011 05:55 AM
sright
22
Sep 2, 2005 07:03 PM
