Cannot get car to idle.( posting in couple spots)
Old May 11, 2019 | 10:44 AM
mini907's Avatar
mini907
So did in frame rebuild on engine so all new pistons rings bearings, time chain etc. 180 compression all the way across. but car will not idle runs down road fine but if you dont keep you foot on the gas it dies. It is throwing no codes,was throwing cam retard code but since I installed two new vanos it has not done that. It was weird though before engine would fire up and sound very smooth and quite. Then it would get loud like lifters and valves were rattling and I would get the cam retard code. But it would idle like this but just sounded terrible. But drove down the road fine and idled fine.
Looks like it is running rich by looking at plugs.
I have changed
Both oxy sensors
Both vanos
Both cam sensors
and temp sensor
thanks for any ideas
Old May 12, 2019 | 08:32 AM
mini907's Avatar
mini907
took valve cover off last night and saw that cam followers are all jacked up not sure
if this is the idle problem or why they are like that. the guides are all worn/chewed up looking but not sure what would have caused them to do that.
mini907
May 14, 2019 07:36 PM
