JCW Misfire Codes F54 JCW
Old May 11, 2019 | 06:40 AM
Krut's Avatar
Krut
I'm at 20k miles and have been having random misfires approximately every 5k miles - usually happens in wet weather - has been in the dealership 4x times - has been towed in twice because reduced power mode and flashing check engine light. Only mod is Dinan Elite. Dealer said there have been multiple flash updates since I bought the car to address the problem. Has anyone else had this happen?
Old May 11, 2019 | 07:25 PM
N0B0DY's Avatar
N0B0DY
You can always try taking the Dinan out of the equation and see if that helps. Do you still have the bypass plug?
Old May 11, 2019 | 07:50 PM
dpcompt's Avatar
dpcompt
Backfires, Dinan???????
Wow, the more I read about Dinan on this forum, I have more doubts about using this on my '19 JCW.
Old May 12, 2019 | 07:32 AM
dscabrio's Avatar
dscabrio
I have a 2017 JCW F54 and had two similar codes early on. Had one flash in between. I attributed it to gas issues since I was on extended road trips both times also in wet (more like monsoon) weather. Since the last code I have had a Dinan Elite installed for 14000 miles with no codes. Not sure you are experiencing the same issue but it certainly did not involve the Dinan in my case.
Apollo_33x
Jul 25, 2016 11:50 AM
apprenticeb
Apr 7, 2014 05:45 AM
jabela
Dec 12, 2013 02:20 PM
2003minicooper
May 3, 2012 03:57 PM
Tennessee Cutty
Feb 21, 2012 07:14 PM
