Electrical Innovate Wideband Wire Firewall Passthrough
For those of you that have installed an AFR gauge (Innovate or others) where did you pass the wideband cable through the firewall?
Just installing an Innovate MTX-L+ and looking for the best (easiest) access through the firewall. I already have some wires and tubing for a boost gauge going through the grommet behind the brake booster but it doesn't look like there's enough room left for the bigger wideband cable.
I routed my O2 wires through the passenger Side cowl drain hole ( US right side ) then followed the brake lines to the driver side. Slit a hole on the firewall. Cleanest route.
gonna do the same thing for my boost, oil pressure and water coolant. From passenger cowl to the driver side.
Navigation & Audio x9331 wire gauge - vampire tap sizing
Maurtis
Dec 31, 2010 08:28 AM
Interior/Exterior Help getting cable through firewall
ColoradoMark
Jan 15, 2004 02:25 PM
