Burning oil!!!
Old Apr 28, 2019 | 07:15 AM
Edgare39's Avatar
Edgare39
Burning oil!!!
I recently got an oil change done at a shop because long story short I stripped the drain plug like an idiot. After I get it back a few days later I noticed that it is blowing a little cloud of blue smoke. It usually does it when I'm sitting at a red light. Other than that it doesn't blue any out the tail pipe. I'm going to check the valve cover later today. Still new to mini so I don't know any common areas I should look into. Any advice would be appreciated.
O.s I'll be calling the shop Monday to find out what oil they used
Old Apr 28, 2019 | 01:26 PM
Minidogger's Avatar
Minidogger
Probably a coincidence. You might want to check the health of the PCV system.
Old Apr 29, 2019 | 05:30 AM
Pramuk's Avatar
Pramuk
I have the same problem.. done with any solutions. Every time when I do oil change I have to use any oil stabilizer with engine oil. This can reduce some smoke.
Old Apr 30, 2019 | 05:12 AM
I like mini clubman's's Avatar
If your getting blue smoke at idle it can be the valve seals. They tend to be done in at 80000 miles or so. High vacuum at idle pulls oil down the valve stem. If you get smoke at higher rpms it could be pcv system. Or I'm way off LOL
Zechariah Retzloff
Aug 25, 2018 07:23 PM
playastarkz123
Jul 14, 2016 06:03 PM
bigbacon
Jun 9, 2013 07:36 AM
Nui
Oct 17, 2008 02:51 AM
