Oil leaks r53
Old Apr 22, 2019 | 08:45 PM
yyj3869's Avatar
yyj3869
Oil leaks r53
Currently i had problem with coolant leak so i went to the shop and noticed that there was oil leak as well.
i replaced valeo clutch kit and rear main seal a month ago. Previous rear main seal did good job but i replaced it anyway.
i’ve also replaced oil pan gasket at the shop about 3 months ago. They sealed with silicone.. can anyone know where it leaks from?
i hope it’s not a rear main seal..
Old Apr 23, 2019 | 05:02 AM
cooper48's Avatar
cooper48
A rear main seal leak would cause clutch slippage that I'm assuming you don't have since you didn't mention it. Have you ever replaced the o-ring on the crank position sensor? That's on the front of the block but, when leaking, the oil can migrate down and back. What is your current oil usage/replacement interval?
Old Apr 23, 2019 | 07:14 AM
yyj3869's Avatar
yyj3869
i’ve replaced crank position sensor o ring as well. Yeah there is no slipping on clutch. I don’t really see dripping on the floor
Old Apr 23, 2019 | 07:23 AM
cooper48's Avatar
cooper48
Wow! That's a tremendous amount of usage in only 2k miles. Given the amount I would suspect a leak at either the oil pan gasket (even though you just replaced it, you might try retorquing the pan bolts) and/or the oil drain plug. First though, I would clean the affected areas so that you can pinpoint the leak once you've driven it again.
Old Apr 23, 2019 | 09:04 AM
Stella11's Avatar
Stella11
I coolant leak may be your water pump or the seal behind it that the water pump connects to the block.
Old Apr 28, 2019 | 08:01 PM
Petr StudniÄka's Avatar
Petr StudniÄka
https://youtu.be/7fSWPz2wX2w
https://youtu.be/Rr7vPTEJDjE
Assuming we re looking at the back of your oil pan where the power steering pump sits... to me that looks like it could be your power steering hoses leaking it hard to tell from the video if what type of fluid exactly it is there also check the oil seperator they re prone to leak
ps: if it turns out to be p/s fluid it could be as simple as changing the reservoir cap o-ring
Old May 7, 2019 | 04:55 PM
yyj3869's Avatar
yyj3869
If oil leaks from rear main seal, is clutch supposed to be slipping?
Old May 7, 2019 | 05:01 PM
yyj3869's Avatar
yyj3869
Old May 7, 2019 | 05:38 PM
cooper48's Avatar
cooper48
The rear main seal surrounds the crankshaft (inside the installed transmission). If it's leaking there, you'll soon have oil on the flywheel, pressure plate and clutch disc causing your clutch to slip.
Old May 7, 2019 | 06:36 PM
yyj3869's Avatar
yyj3869
It's already been over a month since I installed clutch and rear main seal however, clutch runs fine and i don't see any slipping. which means it is not rear main seal correct?
ladzio
Nov 16, 2015 03:32 AM
WhoHasGotTheBlueS
Sep 23, 2014 05:34 PM
ericscottf
24
Jul 6, 2011 07:54 PM
jckonrad
MINI5280
May 21, 2010 01:47 PM
rynegold
Aug 4, 2008 08:34 PM
