R50/53 Heater Core Bypass
Old Mar 22, 2019 | 10:36 PM
Chuck Ray's Avatar
Chuck Ray
Heater Core Bypass
Bypassing my heater core as a permanent solution???
Ok so I live in SoCal. Heater Core sprung a leak and the dealership quoted me over $1,000.00 to fix it. I said kick rocks! Bought the heater core and necessities to replace it. $250.00. Took it to my mechanic friend and he said screw it, just bypass it by connecting the inlet hose to the outlet hose and now my car doesn’t over heat anymore! Sweet! Right? Or am I overlooking something that is going to ultimately bite me in the ***?
All responses welcome
Old Mar 23, 2019 | 06:11 AM
BlwnAway's Avatar
BlwnAway
It will only be a problem if you need to un-fog your windshield in the cold or rain.
To defog or defrost requires heat.
Old Mar 23, 2019 | 06:22 AM
veedubpat's Avatar
veedubpat
Find a different / better mechanic friend and get that thing swapped! It would be super annoying every time the marine layer / fog rolls through and you can't see until it goes away (if it does, by the afternoon...).
Years back I did one in the Jetta that I had at the time - huge PITA and took ~10 hours over the course of a long weekend, but the dealership wanted $800 as a starting value. Unless it's a proper race car, you're going to be quite inconvenienced by not having it hooked up properly.
Old Mar 23, 2019 | 07:30 AM
Tgriffithjr's Avatar
Tgriffithjr
Ditto.
Old Sep 15, 2021 | 02:01 PM
Serafin's Avatar
Serafin
Can you share what size coupler/hose did you use?
is it 5/8 and 3/4?
Thank You
Old Sep 15, 2021 | 02:48 PM
ChiefM's Avatar
ChiefM
Chuck Ray was last on: Last Activity: 03-27-2019 01:46 AM
You won't get a response.
Old Sep 15, 2021 | 05:19 PM
Serafin's Avatar
Serafin
damn. Anyone else bypasses their heater core?
Old Sep 15, 2021 | 08:14 PM
dmath's Avatar
dmath
A friend has done it on a couple of old cars he's restored but he only drives them in summer and never when it's wet out so he has no concerns about needing heat or defogging.
Wenzor
Jan 4, 2021 12:14 PM
Tonefiend
Apr 28, 2018 12:52 PM
CARdiac
Oct 3, 2008 08:30 PM
Elemental
Mar 16, 2008 08:23 AM
