Motor ticking
Old Mar 17, 2019 | 10:38 AM
Stella11's Avatar
Stella11
Motor ticking
Ok, so there is a "knocking" coming from the belt side of the engine compartment. I wanted to start with the easiest fix so I changed the timing chain tensioner and it wasn't the problem. I did not do the last oil change so I do not know what was used. I will be doing the oil gasket soon so I will know if it valve knock when that is done.
I have heard videos of a bad timing chain and it doesn't sound like that but hard to hear on a video.
The last time that it was gassed up, regular was put it in, would that cause it?
Any other thoughts?
Old Mar 17, 2019 | 04:47 PM
TX-Mini05's Avatar
TX-Mini05
Have you checked the’s the oil level? Mine was low one time and it ticked really bad till I topped it off.
Old Mar 17, 2019 | 05:11 PM
Tgriffithjr's Avatar
Tgriffithjr
Get a mechanics stethoscope. They are cheap at harbor freight. You can pinpoint the noise that way. Or you can get a length of rubber hose and hold it to your ear and poke around with the other end. Just be careful around the spinning belt.
rlapinsky
Oct 27, 2017 08:32 AM
jupiterfish
R55 :: Clubman Talk (2008+)
16
Apr 22, 2008 11:38 PM
OmToast
Oct 16, 2003 11:58 AM
TwOMINIs
Jun 10, 2003 02:23 PM
TwOMINIs
May 12, 2003 07:56 PM
