R50/53 wheel spacers
Old Mar 15, 2019 | 01:25 PM
jk6672's Avatar
jk6672
wheel spacers
This sucks, I didn't want to use any wheel spacers and I was under the impression they would fit according to Tire Rack. They are 18x7.5 with a 48mm offset. I've never used wheel spacers, how much does it look like I will need? I have 75mm wheel studs installed.
Old Mar 15, 2019 | 01:33 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Looks like they would be fine, if you were still running the OEM shocks and springs. My guess is 8-10mm to clear the spring.
Old Mar 15, 2019 | 02:26 PM
Tgriffithjr's Avatar
Tgriffithjr
Add about 5mm to keep some space between the tide and strut.
Old Mar 15, 2019 | 06:55 PM
OCR's Avatar
OCR
Remember, the more offset of the wheel AND, the more additional spacers added, the more the front tire will "scrub" in the corners rather than tracking smoothly with no sliding or..."scrubbing". Simple physics, proceed with caution if you want to maintain good handling.
Mike
Old Mar 15, 2019 | 10:25 PM
audihere's Avatar
audihere
Those look great. Can't wait to see it all put together.
Old Mar 17, 2019 | 07:39 AM
veedubpat's Avatar
veedubpat
You're probably good with 5's, but I'd also get some 7.5's to make sure. I'm going to be running, in most likelihood, 5-7.5mm front and 7.5-10mm rear spacers to get my own wheels situated. 17x8 et45 949Racing 6UL - front looks about the same, though I'm waiting on my coilovers to arrive for further fitment. I'm also running a stud conversion, using I think 90mm studs from Turner (though they've been in my garage for 6-7 years now).
Beyond that, if you're concerned, ECS has a sizing kit: https://www.ecstuning.com/b-ecs-part...01202ecs03a~a/ Or $140 and you get $120 store credit back upon return.
Spacers are fine, people that are unknowledgeable about them don't like them. I've had plenty of experience with spacers from 2008 to current, and never had a problem. And this includes running a VW Tiguan on Ohlins entirely too hard around some canyon roads that I used to use on my motorcycle.
EDIT: What tire size are you running? You really need to get at least one tire on there so you can determine actual fitment room / potential issues.
Old Mar 17, 2019 | 09:55 AM
OCR's Avatar
OCR
veedubpat wrote -
Spacers are fine in the back. Can be used in the front...IF...done with care. An offset wheel AND spacers do NOT make up a proper steering car. It's simple 7th grade geometry..!
Me thinks someone needs to do some homework on front suspension geometry..! Get a good book...read carefully, go over it twice if required.
And he says "I'M" unknowledgeable. It appears the "pot is calling the kettle black" in this case..!
Mike
Old Mar 17, 2019 | 01:21 PM
veedubpat's Avatar
veedubpat
Originally Posted by OCR
veedubpat wrote -
Mike
Welcome to the internet, don't take things so personally.
My statement is based on safety, as I don't care about his lap times. As such, my statement stands.
Old Mar 17, 2019 | 02:03 PM
OCR's Avatar
OCR
Not taking it personally in the slightest. I really don't care. Not my car..!
I was just advising. If you want second hand handling, wearing tires more than normal...go for it.
As such, your comment adds to lesser handing characteristics...period. If that's what you like saying to folks. And you comment DOES say something about performance. Reread your comment about haw well it handles in the canyons. I'd think twice about saying how well your car handles in the canyons...when in actuality, it COULD handle a lot better..!
Mike
Old Mar 17, 2019 | 02:14 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Mike
Can I ask what you are running for wheels?
Old Mar 17, 2019 | 03:12 PM
jk6672's Avatar
jk6672
I thought about rental kit to see. 215/40 is the plan.
https://www.americastire.com/buy-tir...-sport/p/33458
Old Mar 17, 2019 | 04:56 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Mike
is this why the SMF autocross cars run big spacers and 275 front tires that stick out 6-8 " ?
OP, I run 10-15mm on my track car to keep the tire from hitting my coilovers, same spot yours will it if you test fit with a tire. If you run 10mm you have to machine the hub, there are some spendy 12mm that work without machining but I like to stick to the 15 $ versions I can get cheap
Old Mar 18, 2019 | 05:04 AM
veedubpat's Avatar
veedubpat
Could you elaborate on why </= 10mm spacers require hub modification? I am planning to run between 5-10mm spacers on my own setup, so would like to know what I have to look forward to. Thank you.
Old Mar 18, 2019 | 05:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
You only have to machine the hub if you want the wheel to be hub-centric. The part of the hub on the car that protrudes is 10mm, so with a 10mm spacer the wheel is no longer hub-centric.
Old Mar 18, 2019 | 05:56 AM
veedubpat's Avatar
veedubpat
Perhaps I'm not understanding this fully, but given that every quality spacer is also hubcentric, would this still be an issue?
Looking further (at a retailer), I see that 10mm is skipped completely. Interesting. I suppose it's time for some more research... I'm glad I saw this, thank you. :beer:
Old Mar 18, 2019 | 06:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The spacer will be hub centric, but there is not enough material left to allow the wheel to be hub centric. With an 8mm spacer, the wheel can still center itself on the hub. With a 12mm spacer, there is enough material on the spacer to provide a "hub" for thee wheel to center itself. A 10mm spacer won't allow for either of those scenarios.
Old Mar 18, 2019 | 09:49 AM
MrBlah's Avatar
MrBlah
the OEM hubs have a lip that is too tall, a 10mm spacer wont sit flush, you have to take about 1mm off the hub so it will sit flush.
afaik these are not really hubcentric, I have ran without hub adapters (forgot them at home) with no ill effects, I always run them just to make mounting easier. Hubcentric bolts look quite a bit different, no taper to them. I use plastic hub adapters there's no way they can hold weight of the car they are not even solid.
On most cars 10mm work fine, but on BMW/mini the lip is just a little bit too tall
Goop
Tires, Wheels, & Brakes
Dec 15, 2019 08:13 AM
GOAZFGP2
Jun 1, 2014 10:15 AM
AutoxCoop
Mar 12, 2014 09:39 PM
jls1203
May 12, 2008 04:32 PM
Maaij
Mar 31, 2007 12:34 PM
