FS:: R56 Boost Gauge Setup- $14.00
Old Mar 11, 2019 | 06:25 AM
Warren2185's Avatar
Warren2185
Price: $14
Location (Region): Midwestern
EDIT: Item is sold. I'm leaving this up because I thought I saw you were supposed to leave it in the Marketplace so people have an idea of what things are going for. I didn't see any other way to notify that it was sold other than edit the original post. I'm sure no one actually cares, but I wasn't sure the proper way.
What's included:
1- Auto meter 15 lb boost gauge
1- Auto meter 35 lb boost gauge (when I added stage 2 tune I needed higher than 15 lbs)
1- Boost port adapter ALTA it has the pressure tube still attached that feeds through firewall
1- Gauge holder and silicone ring to fit.
1- Dash panel already drilled out, you can use this one and not ruin yours. Then put yours back later.
1- It has a simple two wire light bulb included. Find any ignition on feed.
What you might need:
- When you run the pressure tube through the firewall it may not be long enough, but I think it will work. I think the size is in small print on the tube for you to order from someone.
- The ALTA adapter get fastened to the intake under the air cleaner. You will need to get a longer bolt. Just take the old one to the hardware store, match the threads and get a longer one.
- When you take the tube out of the gauge itself, there is a small brass beveled compression thing you, should get a new one. You'll see it when you take out the old tube. Find it in the plumbing section of a hardware store, the exact thing. A two pack of them was less than three dollars I think.
This is off a 2008 MINI Cooper S R56. I'm pulling it out to bring the interior back to stock to sell it. I won't have any information on what else it might fit.
I'm basically asking for the shipping cost. I don't want to throw it away. The total including shipping is $14.00
Paypal only. I guess you just send an email address to me (private message) and I send an invoice to it. Only ship to lower 48 USA
Warren Stilwell
Old Mar 11, 2019 | 02:37 PM
nayr924's Avatar
nayr924
PM Sent
Old Mar 29, 2019 | 04:55 AM
Damion Brown's Avatar
Damion Brown
Is this still available???
Am intrested
Old Mar 29, 2019 | 05:17 AM
iwashmycar's Avatar
iwashmycar
Originally Posted by Damion Brown
Am intrested
says it sold
Old Mar 29, 2019 | 02:11 PM
Beka_2JZ's Avatar
Beka_2JZ
did you sell it for JUST 14 BUCKS ???
Old Mar 29, 2019 | 02:35 PM
Warren2185's Avatar
Warren2185
Yes, I did sell it for $14. I was just hoping to find someone that could use it and cover the shipping.
Old Mar 30, 2019 | 01:57 AM
Beka_2JZ's Avatar
Beka_2JZ
Oh My God ! How could i Miss such a good deal !
may be you've got something else ?
SpiceOrangeR56
Sep 6, 2016 07:19 AM
TEEZY
Jun 6, 2014 07:57 PM
HorizonBLueN18
Oct 3, 2013 02:05 PM
scott48
Mar 1, 2008 01:54 PM
mistro
Electrical
Jul 6, 2006 11:58 AM
