R50/53 Crank angle sensor seal replacement w/o service mode
Old Mar 4, 2019 | 09:18 PM
mini_me123's Avatar
mini_me123
Is it possible to get at the sensor w/o putting the car in service mode (r53)? I am seeing these two vids for reference.
Old Mar 5, 2019 | 03:15 AM
Fastlane's Avatar
Fastlane
Possible? Perhaps, but I can’t imagine doing that. I replaced mine last summer and it was hard enough to do reaching in there in service mode.....it’s tight and you can’t really see it well from above.
putting the car in service mode really isn’t all that bad/hard. Get some long bolts and follow ModMinis instructions.
Old Mar 5, 2019 | 05:49 AM
cooper48's Avatar
cooper48
+1 on Fastlane -- once you do service mode for the first time, it becomes very easy the second time. Shouldn't take more than 20-30 minutes and your access is vastly improved.
Old Mar 5, 2019 | 10:56 AM
Zsm's Avatar
Zsm
Yep, once you’ve done the service mode a few times, it goes quickly.
I definitely wouldn’t advise replacing the crank sensor seal blindly. There is a ton of gunk near that sensor and the last thing you want to do is shove that dirt into your motor while you fiddle with it.
Old Mar 5, 2019 | 07:32 PM
MCSBen's Avatar
MCSBen
I followed this how-to to replace the o-ring without service mode.
https://www.motoringalliance.com/art...eplacement.32/
Old Mar 7, 2019 | 11:45 PM
AnubisBC's Avatar
AnubisBC
Definitely seems easier to me to just go into semi-FES mode. You don't need to drain or remove the radiator to get the proper clearance if you aren't afraid of removing the supercharger inlet tube. Once done a couple times, it's easier as a starting point. Also doesn't require much time under the car, which to me is a bonus.
Old Mar 8, 2019 | 06:50 AM
TheBigChill's Avatar
TheBigChill
I have very narrow hands, and I did it 100% blind without removing a single thing from the car. That said, it was challenging and took about 45 minutes and my hands were very chewed-up afterwards.
Old Mar 8, 2019 | 11:22 AM
AnubisBC's Avatar
AnubisBC
That's pretty impressive! I personally find the process of the tear down to be quite meditative. I could never get my hand jammed in like that without serious injury.
boiler up
How to
123
Aug 23, 2024 07:39 AM
jjcsnlynn
Jan 7, 2018 08:39 AM
Powashiftin
Feb 2, 2012 08:27 AM
