R50/53 A//C service parts question.
Old Feb 28, 2019 | 08:05 PM
dredpyrt's Avatar
dredpyrt
The a/c on my 06 JCW is i need of recharging but i was wondering if should r& r a few things while im at it . Generally i like to change out the receiver/dryer but this car only has 56K miles and has never been apart and isnt venting refrigerant. Should i leave it be or swap in a new one?. Thanks!
Old Feb 28, 2019 | 08:15 PM
A383Wing's Avatar
A383Wing
If I remember, the receiver dryer is part of the condenser in front of the radiator, it's not serviced separately, at least not on my two cars.....
Bryan
Old Feb 28, 2019 | 08:18 PM
dredpyrt's Avatar
dredpyrt
a/c
Pelican list a separate receiver/dryer on there site.
Old Feb 28, 2019 | 08:49 PM
A383Wing's Avatar
A383Wing
If your AC is just a little low, I would just evacuate and recharge.... if you want to replace the dryer, you will need to put the correct amount of pag oil in there as well.
I still don't see how to just replace the dryers on my two cars.... looks to be part of the condenser to me
Bryan
Old Mar 1, 2019 | 04:07 AM
JAB 67's Avatar
JAB 67
It is clearly separately replaceable. I did it last year.
Old Mar 1, 2019 | 05:42 AM
Tgriffithjr's Avatar
Tgriffithjr
If it’s just a little low just recharge it. If you evacuate it you will have to draw a vacuum on the system with a pump. Better to find the source of the leak and correct that problem at some point. If you replace the compressor you will need to replace the dryer in order to maintain the warranty on the new compressor. Vacuuming the system at that point serves two purposes; creating a negative pressure in the system to allow a complete recharge with coolant and boiling off any moisture that was introduced when the system was opened.
Old Mar 1, 2019 | 05:57 AM
JAB 67's Avatar
JAB 67
It's not 'coolant' it's 'refrigerant.'
Old Mar 1, 2019 | 06:36 AM
cooper48's Avatar
cooper48
Some MINIs have separate replaceable receivers and dryers and some don't (my 2004 is a single unit for instance). A leak-down test will let you know if your AC system can hold a vacuum. With only 56k miles, and if your system has never been open, it's doubtful that your dryer/receiver needs replacing. Your AC repair shop will want to replace it anyway because they want the revenue but if, after a recharge, you're not losing refrigerant and getting 40F through the interior vent I say, "if it ain't broke don't fix it."
Old Mar 1, 2019 | 06:44 AM
Tgriffithjr
Really? I’m sure the OP wouldn’t try and pour coolant into his system.
Old Mar 1, 2019 | 08:18 AM
buzzsaw's Avatar
buzzsaw
Same thing happend to our 06 R53. Took it to my favorite indie shop and after an inspection of all components, it only required a recharge of a half pound of refrigerant to make it good again. After thirteen years of ownership, the tech and I were both impressed. He said the manual states that the system must be charged down to the gram of required refrigerant to meet factory spec so as to not overcharge the system. He also mentioned that a DIY without the proper equipment is not a prudent move with such tight tolerances- risking the chance of an overcharge. So this again this convinced me to let the pros handle this one.
Old Mar 1, 2019 | 12:16 PM
A383Wing's Avatar
A383Wing
I just looked at my '04 and the '06.....both have the dryer as part of the condenser, not a replaceable item by itself......and I agree with coooper48 with what he said above......and don't try to do it yourself......these AC systems are real finicky about proper AC charge for optimum operation......
Bryan
Old Mar 1, 2019 | 12:21 PM
JAB 67's Avatar
JAB 67
Bryan: I think you are mistaken; on my 2004 the part is clearly replaceable.
Old Mar 1, 2019 | 07:59 PM
dredpyrt's Avatar
dredpyrt
a/c
I know a guy who does good work and wont upsell me. Just have to allocate some time to go see him.
Kris Lal
Aug 19, 2019 08:49 AM
iSUPR3ME
Aug 31, 2013 03:19 PM
minilover2007
Dec 2, 2009 10:18 PM
Aviators
Feb 13, 2009 09:22 AM
sneves
40
May 28, 2006 07:48 PM
