2005 MCS - 6spd Auto (Aisin TF60SN/09G) - Flexplate Cracked
Old Feb 24, 2019 | 06:37 PM
BTRMayfair's Avatar
BTRMayfair
Pulled transmission - Aisin TF60SN - and rebuilt. New seals, frictions, steels, etc. Replacing valve body with remanufactured.
When pulled transmission also found flexplate cracked.
Concern is WHY did it crack... root cause determination before put back together.
2005 MCS 6 speed automatic CRACKED flexplate.
Old Feb 25, 2019 | 05:14 AM
Tgriffithjr's Avatar
Tgriffithjr
They just crack from stress and use. It’s not uncommon to see it on any engine that has one including V8s. It’s called a flex plate because it’s suppose to flex. Anything that flexes enough will eventually crack. If all your converter bolts were in place and tight I wouldn’t be worried. You can try buying a good quality plate to avoid it in the future.
Old Mar 8, 2019 | 10:17 AM
BTRMayfair's Avatar
BTRMayfair
Thanks for comments -- I've order another -- and will see if non-issue once replaced
Old Mar 10, 2019 | 09:03 AM
BTRMayfair's Avatar
BTRMayfair
Closing the loop for any future forum searches.
Believe discovered root-cause of flexplate crack -- likely misalignment by the previous owners (non mini) shop that replaced automatic transmission about 10-15k miles ago. As I've removed transmission -- I've discovered many things this shop did wrong when reassembling -- the latest is that as started to put all back together -- discovered missing alignment dowels! Without these dowels -- I'm betting alignment was off far enough that ultimately flexplate cracked.
Old Mar 10, 2019 | 03:32 PM
Tgriffithjr
How was the alignment off and the bolts still line up to tighten?
MF-DIF
Oct 24, 2017 10:39 AM
06mcsvert
Jan 22, 2017 11:17 AM
Laserman
Oct 17, 2014 06:24 AM
GSequoia
Sep 23, 2013 05:33 PM
MiniDad08
May 28, 2008 10:37 AM
