Frustrating boost leak?
Old Feb 3, 2019 | 10:56 AM
MrGrumpy's Avatar
MrGrumpy
Hey all, I’m just about to the point of pulling my hair out! I will post this in the Gen 2 section as well if mods allow, since this isn’t necessarily specific to an R60 but any N18 Mini I hope.
OK here is the issue:
I have 40mm turbo installed on my 2012 R60 S All4. For a while now and it’s getting more noticeable lately, I have had this weird what I think is a boost leak or vent of some sort.
Im wondering if maybe my pressure converter or vacuum tank may be bad. But I’m not getting the classic kazoo sound at shut off, no odd noise at shut down at all. The car runs great, so it doesn’t seem to have a vacuum leak. But under a light load while building boost, I will sometimes (more often recently) get a brief whistle or hoot almost like a tea kettle whistle of pressure releasing somewhere under the hood. It’s not the diverter. It will happen and I can feel the power drop a bit as it loses a couple psi just before the diverter opens. I have changed the diverter multiple times and now have a GFB DV+, but still get it. Under harder acceleration or higher boost levels it seems to seal up and hold pressure fine. No whistle or power drop.
does anybody have any idea what this may be? I’m getting frustrated! I’ve pressure tested all of the charge pipes and FMIC and no leaks there at all. I keep thinking it’s the pressure converter but don’t want to just throw parts at it blindly. Does anyone have any tips for testing the converter/boost solenoid?
any help here would be tremendously appreciated!
thanks!
Grumps
Old Feb 6, 2019 | 06:52 PM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
thanks!
Grumps
It likely *is* a vacuum leak. I recommend that you acquire a smoke machine or go to a garage which knows how to use one. That and a stethoscope or remote mic and headphones. My TT leaked a bit under boost and lost that Puh-shuuuusssh! sound when the DV let off excess pressure. The vacuum lines get hard and brittle with age and will crack and split. Might be worth buying a reel of hose and cut it to length and reinstall all of it.
One other less obvious thing to check is the boost control valve. I don’t know if that’s what it’s called on the MINI but that, too, was a notorious issue with the TT and likely easy to replace.
Old Feb 7, 2019 | 10:18 AM
MrGrumpy's Avatar
MrGrumpy
I have been suspecting the boost control solenoid too. I can’t seem to find anything else. I suppose I need to figure out how to do a smoke test, because I don’t like paying others to work on it, maybe I’m old school, maybe I’m just cheap.....maybe a little of both! Lol
thanks for the response. I have been searching but can’t really find much on how to test the solenoid first, because I loathe just throwing parts at a problem. Time to think on it a bit more.
Old Feb 25, 2019 | 11:31 AM
MrGrumpy's Avatar
MrGrumpy
It’s the part between #’s 7 & 8
This thing! Ugh!
Son of a .......
I think I’ve FINALLY tracked it down and found the culprit! It’s the dang coupler in the cold-side boost tube that used to have to noise maker attached to it Mine never had the noise maker, but at least for a time, they used a coupler that is almost identical except for the port for the noisemaker. It’s leaking around the seal on the top. So I ordered up a Forge noisemaker delete pipe that should eliminate that whole piece. Hopefully that will do it! It will be here in a couple days.
Old Feb 26, 2019 | 05:54 AM
eric.stewart
This thing! Ugh!
Son of a .......
what’s the “noisemaker’s” function? Hope you found it. How’d you find the leak?
Old Feb 26, 2019 | 06:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My 2012 Clubman with N18 engine had the same intermediate tube in there. Seems earlier cars had the multi-piece design, and later cars went to a one-piece design. I replaced mine with the NM pipe kit.
Old Feb 26, 2019 | 09:06 AM
MrGrumpy's Avatar
MrGrumpy
It’s a dumb design decision. I’m dumb too I suppose, since I had mentally eliminated that part as a suspect for the leak because I took it apart and put it back a few times and never seemed to make a difference, but I never actually pressure tested that part. I’m just glad I finally found the problem! The one piece hose that I ordered will hopefully do the trick.
Old Feb 26, 2019 | 10:58 AM
Sometimes is that one part you dont think about, then your like dang, should have thought it through. Been there done that.
Old Feb 26, 2019 | 02:33 PM
MrGrumpy's Avatar
MrGrumpy
Yep, you would think that I would know better by now, but.....lol.
Thanks, by the way, I ordered the hose from ECS. You guys had the best price on it. Just waiting for it to arrive.
Old Feb 26, 2019 | 03:10 PM
eric.stewart
Still haven’t answered my question? :-)
MrGrumpy's Avatar
MrGrumpy
I apologize, I didn’t notice your post right away. The noisemaker was a contraption that pumped artificial engine noise into the cabin. They stopped using it around the time of the switch to the N18.
I had been hearing it for a good while now, giving me just a brief whistle every now and then. Just enough to be super annoying! And a small flat spot in power when it would happen. I have been looking for it unsuccessfully for a while.
The last time I had it apart there, put a little bit of lube on it to enhance the seal and cleaned it up really good inside and out. Well the last time I had my head in there looking at the vacuum tank and lines, I noticed some dirtiness around the top of the coupler. Then I jiggled it a little and realized it’s not a tight seal there, as it moves quite a bit. So with my super thinking cap on, I decided to wrap it in duct tape and see if the sound changes. Sure enough it did! Now I can see where it’s leaking at. So the one piece delete pipe should solve the problem by eliminating the coupler altogether.
Old Feb 26, 2019 | 03:29 PM
eric.stewart
^^ Thanks.
Old Mar 4, 2019 | 06:22 PM
dmath's Avatar
dmath
Good detective work, Mr. Grumpy. Thanks for sharing. I keep making mental notes of these procedures and hoping that I'll be able to locate them in my addled brain when I need them.
Old Nov 17, 2019 | 07:38 AM
7rhSon's Avatar
7rhSon
On my 12' countryman S fwd.recently I've had a kazoo/buzzing sound in the front.. when I release the pressure via the expansion tank it will calm down.. I've been told that it's a normal thing with the auxiliary water pump.. but I never recall hearing this.. so with the boost solenoid valve on it's way out are there other signs? From time to time I will get a half engine power light on and the turbo kicks off.. I restart my car and things are ok.. I get no codes when I scan the car with my schwaben bmw/mini scan tool.. just curious for any thoughts
Old Nov 15, 2024 | 08:15 AM
Rocker from Detroit's Avatar
Rocker from Detroit
Hello- it's been some years so I don't necessarily expect a reply. Would be nice, though. I have the exact problem with my 2013 Roadster JCW. A whistle and loss of boost at low throttle but generally seals up under full throttle. I have an upgraded turbo and a tune that is supposed to allow for 350hp. I have to open the waste gate way over to the hot side to stop the whistle but do not have much boost pressure/power at that point (maybe 16psi max). I have replaced the noise maker and two adjoining pipes with one FORGE pipe and have essentially changed everything pre and post turbo multiple times but still have the issue. I am told it is because the exhaust is the bottleneck, resulting in the motor being pressurized and the air leak/whistle coming out of the valve cover. I did upgrade the exhaust to include a Scorpion catted downpipe (2.5") and 3" Vibrant Performance resonator and Magnaflow muffler and all other piping is 3 from the 2.25" and 2.5" stock pipes". Apparently, this "upgraded" exhaust is only good for 250hp to 300hp. Any help from anyone to resolve this once and for all will be greatly appreciated.
norcalmc40
Jan 6, 2013 06:40 PM
pezking6983
May 31, 2012 04:56 AM
advancemini
11
May 25, 2008 01:07 AM
staz87
Sep 26, 2007 09:27 PM
jcap287
MINI Camera and Video
Aug 12, 2007 10:00 PM
