R50/53 Powerflex bushings
Old Jan 26, 2019 | 11:02 AM
jk6672's Avatar
jk6672
Powerflex bushings
What is the easiest way to get the purple lip into the black part of the bushing?
Old Jan 26, 2019 | 11:38 AM
BruceJ's Avatar
BruceJ
Not that it will ease your labors but, quite a few of us have felt this pain. Somehow the back of the bushing gets compressed after it goes in the mount.
Here's a few things to try:
1. With everything out of the car you can try a F style clamp if you have it, but they will likely just back out again.
2. With the subframe back up in the car as you are trying to get it all assembled, try a ratcheting strap. Loop it between the first big hole on the control arm and one side or the other of the bushing mount.
3. Another method discussed is using a crowbar or really long & heavy duty screwdriver to push it in and with your 3rd hand then maneuver/connect the inner ball joint.
Good Luck
Bruce
Old Jan 26, 2019 | 12:29 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Make sure you have plenty of silicone grease between them. Then use one of this and whack it really hard. It requires a lot of well aimed blows.
Just image it is the ex-whatever
Old Jan 26, 2019 | 01:08 PM
jk6672's Avatar
jk6672
Thanks, I’ll give the dead blow hammer a wack.
Old Jan 27, 2019 | 12:01 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I put the lube in the black part of the bushing then put the purple center in the black part. If it is tight I use a pair of huge pliers to pop them in, then slide the whole thing on the control arm shaft.
But also have done it with a hammer like they said before.
Old Jan 27, 2019 | 12:29 PM
jk6672's Avatar
jk6672
The blow hammer worked perfect. I lubed the purple and banged it in, then inserted the control arm tip.
meb
Suspension
132
Dec 29, 2011 03:10 PM
minimad2
Suspension
Jul 12, 2004 04:45 PM
DancesWithCones
General Discussion
Oct 6, 2003 04:31 PM
