R50/53 2005 brake light problem
Old Jan 25, 2019 | 05:58 PM
Michael Hayes's Avatar
Michael Hayes
I feel like a total fool for asking about this, but has anyone had a problem with a replacement brake light bulb working in the reverse order that it's supposed to work? I've worked on cars for 50 years and I can't believe that I can't sort out why the wrong filament is lighting when all the lights are on, and why the wrong filament lights up when the brake is depressed.
I check the specs at the MINI dealer, and it's a 21w/ 5 watt dual filament bulb with a bayonet stud type bottom, made by
Slyvania.
Any Ideas?
Thank you
Old Jan 25, 2019 | 07:44 PM
Tgriffithjr's Avatar
Tgriffithjr
Maybe have it twisted in 180 off?
Old Jan 26, 2019 | 03:28 AM
BruceJ's Avatar
BruceJ
90% of electrical problems tend to be either a short or a lost ground. Bust out your multimeter and test the related ground wires to see that that first they actually ground, and then to make sure they haven't shorted to another wire, IIRC brake lights were one of 5 different ways water intrudes into the rear hatch area on R53's. Just a little corrosion in the right place will do this.
Old Jan 26, 2019 | 10:32 AM
Michael Hayes
It does seem that it was a 180 degree problem. I had no idea such a thing could happen to a brake light. Thank you.
Old Jan 26, 2019 | 04:34 PM
Tgriffithjr
Glad to be of help. Even a broken clock is right twice a day. Yeah if the socket is a little loose or corroded it’s easy to twist the bulb in the wrong direction. I always look at the bulb to determine which protrusion is lowest and then look at the socket to match it up.
Old Jan 27, 2019 | 01:14 PM
Michael Hayes
I learned something new. Thank you. I can't believe that I had never knew that there's a high lug and a low lug on those bulbs!
Warthog1956
Oct 6, 2014 12:45 PM
caseyw
Dec 26, 2009 12:48 PM
jmainella26
Dec 11, 2009 06:20 PM
