R50/53 Bolt size for the 10mm starter heat shield bolt?
Old Jan 21, 2019 | 09:38 PM
mini_sd's Avatar
mini_sd
Does anyone happen to know either a part number or the size for the10mm bolt in the starter heat shield. 2003 R53 mcs. It basically attaches to the oil filter housing. I dropped the bolt and now apparently it is just gone. Thanks for the help.
Old Jan 22, 2019 | 07:46 AM
Tgriffithjr's Avatar
Tgriffithjr
Refer to your other post for the answer.
Old Jan 22, 2019 | 08:21 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
find it at RealOEM. If it were me I would just go to a hardware store and get one. I would try bring the one for the header heat shield after checking that is the same thread. Even HD should have it.
Old Jan 22, 2019 | 07:23 PM
jk6672's Avatar
jk6672
Let me know if you still haven’t found the length, I’ll mic mine when I get home. Just took it off last night.
Old Jan 22, 2019 | 07:32 PM
A383Wing's Avatar
A383Wing
Do you mean the 10mm is the hex head size? If so, I'm thinking the thread size is 6 x 1.0mm ..... maybe about 1/2" long......ava availa at any parts store or hardware store
Bryan
cavaliers60
Jul 18, 2018 05:07 AM
Mar 1, 2016 11:55 AM
wakeslayer
Jan 28, 2013 05:57 AM
JCampos
Oct 3, 2012 12:48 PM
Mr. Incredible
Mar 8, 2010 04:07 PM
