R50/53 Worth it to remove engine?
Old Jan 17, 2019 | 10:12 AM
89325iturbo1's Avatar
89325iturbo1
Picked up a project 2003 r53. It needs work in various areas. I will most likely be doing a head gasket, clutch, other maintenance items. Plus probably a couple upgrades.
id like to get a good clean on the engine bay, and engine as well. (Oil leaks, and ps leaks over the years). Was just wondering if it would probably be easier just to remove the whole engine?
thanks
Old Jan 17, 2019 | 12:04 PM
BlwnAway's Avatar
BlwnAway
thanks
Me personally, I don't think it's that bad of a job, better access to everything and easier to do the clutch, not to mention doing the oil pan gasket and main seals on an engine stand as well.
Hell, I wire brushed and painted both the engine and transmission while they were out.
Plus the added benefit of having a better understanding of the whole setup.
Old Jan 17, 2019 | 01:01 PM
89325iturbo1
^^thats my thinking. I like things to be cleaned. I'm sure I can find a write up on the removal, or mod mini probably has a video.
Old Jan 17, 2019 | 02:30 PM
BlwnAway's Avatar
BlwnAway
At the very least you'll find videos of all the individual sub-sections (for lack of a better term)
Once it starts coming apart it's actually pretty intuitive.
To be VERY general:
Service Mode
CAI (and ECU)
Wiring
Axle
​​​​​​Main Mounts
Take your time,, Bag-N-Tag everything, plenty of photos, and you'll be fine.
Old Jan 17, 2019 | 02:47 PM
cooper48's Avatar
cooper48
+1 on BlwnAway - removing the engine is a great way to learn about your MINI plus makes part replacement, i.e., seals, gaskets, damper, water pump, supercharger, clutch, etc., a breeze.
Old Jan 17, 2019 | 03:21 PM
mslatter's Avatar
mslatter
Take videos. With bright lights. And move around a lot. I can’t count how many times I missed the critical view of a part with a still pic that I might have snagged with video because it captures so many more frames. And the movement of the camera allows you to get a sense for the three dimensional relationship between parts that sometimes gets flattened by stills.
Old Jan 17, 2019 | 03:45 PM
89325iturbo1
Thanks for the suggestions guys. I removed engines from various other cars. Labeling, bagging, ect is a must. So it sounds like engine removal is the way I'm gonna go.
Old Jan 21, 2019 | 06:58 PM
derangedoffroad's Avatar
derangedoffroad
I’ve pulled engines out of multiple R53 Minis and it really isn’t a whole lot more work to pull the engine with the transmission attached than it is to just pull the transmission. If you are doing a head gasket it will give so much easier access to the timing cover and chain. My suggestion would be to pull it.
MotorWorf
R55 :: Clubman Talk (2008+)
Apr 29, 2013 12:18 PM
IQRaceworks
Nov 10, 2011 11:57 AM
woahfactor3
Cooper (non S)
44
Dec 21, 2007 11:42 AM
Eddie@1FastMINI
Nov 27, 2007 12:33 PM
RaT48
Sep 4, 2007 06:47 PM
