R50/53 Axle
Old Jan 12, 2019 | 11:28 AM
jk6672's Avatar
jk6672
Axle
How do I remove the drivers side axle? Do I need to remove the boot in order to do this?
Old Jan 12, 2019 | 01:18 PM
AoxoMoxoA's Avatar
AoxoMoxoA
The rubber boots? No.
After removing the axle nut, disconnecting the control arm and lower ball joints & tie-rod from the hub, swing the entire knuckle assembly outward until the splined shaft of the axle slides pulls out of the hub, making sure you have first supported it so it does not drop. Then from underneath, you'll need a longish pry-bar to "pop" it out of the gearbox, as unlike the passenger side which just slides out, it is retained in by a circlip.
Mod MINI's video on a clutch replacement shows the "popping out" method for the driver side axle at 22:43 of this video:
Old Jan 12, 2019 | 01:43 PM
jk6672's Avatar
jk6672
I’m already there, nothing in the wheel well but a brake caliper suspended by bungy. Yeah I’m looking for that clip.
Old Jan 12, 2019 | 02:28 PM
AoxoMoxoA's Avatar
AoxoMoxoA
The circlip is inside, permanently attached to the end of the inboard axle splined shaft. It snaps into place, when the axle is pressed into the gearbox, retaining it.
That’s why the axle needs to be ‘popped’ out.
Old Jan 13, 2019 | 06:44 PM
jk6672's Avatar
jk6672
MODmini must of seen my thread He just released this vid today
He’s using aftermarket axles that he said are pretty good which contradicts all that I’ve heard. I already spent a grand on the new axles so can’t go back down that road
jetsr6
Jun 2, 2021 08:19 PM
DVLMINI
May 23, 2003 12:42 PM
Lenny
Nov 22, 2002 01:30 PM
