Drivetrain F56 Belly Pan/Under Engine Cover?
Old Jan 7, 2019 | 01:48 PM
johntotah94's Avatar
johntotah94
I was driving through snow last night and my under engine cover or splash guard ripped right off.
Has anyone seen any good alternatives to the stock one? I'm sure the mounting locations for the screws are stripped so not sure if I want to order an OEM one at the moment.
I came across this one.
Thoughts?
https://www.ecstuning.com/b-rennline...plate/u06~rel/
Old Jan 7, 2019 | 02:17 PM
We have it here, all the guys like it from what I have heard.
https://www.northamericanmotoring.co...plate-new.html
One of the MINI guys on here was the test car for it:
https://www.northamericanmotoring.co...lly-pan-4.html
We also have the factory aftermarket fabric ones here: 51757343141 till 2020 model years. https://www.ecstuning.com/Search/Sit...h/51757343141/
Some people are doing the F57 MINI Convertible Metal pan here: 51617391724 & 51717384760 https://www.ecstuning.com/b-genuine-...e/51617391724/ and https://www.ecstuning.com/Search/Sit...h/51717384760/
Old Jan 8, 2019 | 09:45 AM
johntotah94
Thanks. Is it possible to send me install instructions?
I am just concerned if the mounting locations because the original mounting locations are all stripped under my car. Unless this uses entirely new areas.
Old Jan 8, 2019 | 10:05 AM
bratling's Avatar
bratling
Super Moderator
It uses stock mount points, so you may need to repair those first. The front three, where it attaches to the bumper, uses special c-clip nuts that come with the Rennline shield (or did on my prototype anyway). The rest reuse standard fasteners. I believe you can just order replacement expanding receiving nuts and more screws using the part numbers here:
http://www.realoem.com/bmw/enUS/show...diagId=51_9649
if you are uncertain about identifying the parts yourself, and are near a MINi dealer, just go to the parts desk. They’ll help you determine which and how many you need. I suspect ECS can hook you up with those parts too. Looks like you’d need 7 of part number 6, and 4 of part 7, and 11 hex bolts. (No idea why the diagram says you’d need 27. Maybe that includes the count for other nearby panels.)
Old Jan 8, 2019 | 10:50 AM
I was just going to post up the PDF from rennline, waiting to hear back from them. +1 you can just dump those part #'s, thanks bratling for the help!
Old Jan 8, 2019 | 11:11 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
The only "bad" thing about them and what has stopped me from buying that is the lack of access panels for the oil filter and drain plug.
With that being said. it could be easily modified. In its current state, it would have to be taken off every time you change the oil.
Old Feb 21, 2019 | 03:57 PM
6FT6's Avatar
6FT6
I’ve got it on my F56 as well. ECStuning is always taking my money
Old Feb 21, 2019 | 04:21 PM
bratling's Avatar
bratling
Super Moderator
Only takes a couple minutes extra. And if it had cut outs for the oil drain and filter access it would give up a good bit of strength on that side. The protection is worth the trade off to me.
(They could also have designed it with some sort of lock-in-place access panels that retain most of that strength, but then you are adding a lot more complexity, which drives up the cost of making it. There’s always a trade off in design!)
Old Feb 21, 2019 | 06:49 PM
Mini_Vinnie
Moderator
Oh trust me, I bought it. I was just thinking out loud
gimmea250swb
Jun 1, 2022 08:34 AM
scubus
GP Talk (2006)
Apr 15, 2019 07:33 PM
cooper48
Feb 13, 2019 08:09 AM
jk6672
16
Oct 21, 2018 02:28 AM
