F56 Belly Pan/Under Engine Cover?
I was driving through snow last night and my under engine cover or splash guard ripped right off.
Has anyone seen any good alternatives to the stock one? I'm sure the mounting locations for the screws are stripped so not sure if I want to order an OEM one at the moment. I came across this one. Thoughts? https://www.ecstuning.com/b-rennline...plate/u06~rel/ |
We have it here, all the guys like it from what I have heard.
https://www.northamericanmotoring.co...plate-new.html https://cimg6.ibsrv.net/gimg/www.nor...9d79f947ec.jpg One of the MINI guys on here was the test car for it: https://www.northamericanmotoring.co...lly-pan-4.html We also have the factory aftermarket fabric ones here: 51757343141 till 2020 model years. https://www.ecstuning.com/Search/Sit...h/51757343141/ Some people are doing the F57 MINI Convertible Metal pan here: 51617391724 & 51717384760 https://www.ecstuning.com/b-genuine-...e/51617391724/ and https://www.ecstuning.com/Search/Sit...h/51717384760/ |
Thanks. Is it possible to send me install instructions? I am just concerned if the mounting locations because the original mounting locations are all stripped under my car. Unless this uses entirely new areas.
(Post 4442236)
https://www.northamericanmotoring.co...plate-new.html https://cimg6.ibsrv.net/gimg/www.nor...9d79f947ec.jpg One of the MINI guys on here was the test car for it: https://www.northamericanmotoring.co...lly-pan-4.html |
Originally Posted by johntotah94
(Post 4442435)
Thanks. Is it possible to send me install instructions? I am just concerned if the mounting locations because the original mounting locations are all stripped under my car. Unless this uses entirely new areas. http://www.realoem.com/bmw/enUS/show...diagId=51_9649 if you are uncertain about identifying the parts yourself, and are near a MINi dealer, just go to the parts desk. They’ll help you determine which and how many you need. I suspect ECS can hook you up with those parts too. Looks like you’d need 7 of part number 6, and 4 of part 7, and 11 hex bolts. (No idea why the diagram says you’d need 27. Maybe that includes the count for other nearby panels.) |
I was just going to post up the PDF from rennline, waiting to hear back from them. +1 you can just dump those part #'s, thanks bratling for the help!
The only "bad" thing about them and what has stopped me from buying that is the lack of access panels for the oil filter and drain plug.
With that being said. it could be easily modified. In its current state, it would have to be taken off every time you change the oil. |
I’ve got it on my F56 as well. ECStuning is always taking my money |
Originally Posted by Mini_Vinnie
(Post 4442452)
With that being said. it could be easily modified. In its current state, it would have to be taken off every time you change the oil. (They could also have designed it with some sort of lock-in-place access panels that retain most of that strength, but then you are adding a lot more complexity, which drives up the cost of making it. There’s always a trade off in design!) |
Originally Posted by bratling
(Post 4452222)
Only takes a couple minutes extra. And if it had cut outs for the oil drain and filter access it would give up a good bit of strength on that side. The protection is worth the trade off to me. (They could also have designed it with some sort of lock-in-place access panels that retain most of that strength, but then you are adding a lot more complexity, which drives up the cost of making it. There’s always a trade off in design!) |
