Oil Pan: Silicone gasket vs fel-pro gasket
Fixing a nasty curb hit on my dad's r56. I ordered all the parts I needed before I started working. Rock auto had only the normal type gaskets available so I ordered the felpro oil pan gasket. It was only after I removed the oil pan that I noticed mini had used a silicone gasket. The picture of gasket (still in the mail, hasn't arrived) looks like it fits.
My question is, (knowing there must've been a reason mini switched from gasket to silicone), has anyone used and had success with the felpro gasket? I rather not deal with returning it, but if the felpro won't keep the oil in for the long run, I rather use the silicone. Thanks in advance.
My mini just had silicone gasket glue. There was no actual gasket. I ordered the felpro gasket from rockauto.com also and its a good quality piece. I haven't installed it yet as I'm waiting on a few bungs to weld to the pan. I think my repair manual says to just use silicone glue also, no gasket required.
If I'm not mistaken, the Bentley specifically mentions a fiber or some other material gasket and I think says not to use silicone. Paraphrasing here as it's been a couple months since I read it. I had already ordered the silicone and used it. It held the first time; I had to do another teardown to replace rings that were bad. It was a b!tch to get the pan off again. I ended up whacking it hard multiple times with a 2x6 to get it loose. As far as I know that's the only downside.
After the ring work I used silicone again. Was contemplating not ordering another tube as I THOUGHT I could go another round with the 2nd half but chickened out. The 2nd round is also successfully holding after ~100 miles. I'm a fan.
Lex2008
Aug 9, 2024 12:54 PM
AoxoMoxoA
19
Nov 5, 2015 01:30 PM
sempaipaul
Sep 15, 2015 06:49 PM
