New Fuel Injectors
Old Jan 2, 2019 | 06:13 PM
danraabe's Avatar
danraabe
New Fuel Injectors
I decided to replace my fuel injectors. My newly machined engine is sitting on the garage floor. Would anyone care to simply scribe a step by step to installing the new injectors including the fuel rail or comment on what I just did?
1) I used the smallest sizing gizmo in the fuel injector kit. Garage reasonably warm. Left the tool on for a few minutes on each injector.
2) silicone grease on the green o-rings and slid them into the fuel rail with new spring clips
3) placed all the injectors into their respective cylinders as far as they would go
4) leveraged them home with the fastening bolts in a pattern at short twist at a time while keeping the angle of the injectors at what appears to be "normal"
5) once completely seated I torqued the bolts and taped off the open end of the rail
BTW - I fully cleaned the fuel rail with carburetor cleaner only where the injectors fit inside until there was no dust or fluid or any particles
Any thoughts. I hope I did this correctly. The Bentley manual made it seem easy. I don't think it's easy.
Thanks, Dan R
Old Jan 3, 2019 | 07:16 PM
oldbrokenwind's Avatar
oldbrokenwind
Thanks, Dan R
I used all three of the kit gizmo's, sequentially. Did one injector at a time, from removing old parts to inserting into the head. After all injectors installed, then added the rail, without lubing the o-ring.
My '07 injectors have a guide that mates with a guide hole in the head --- there's no angles involved. Maybe the other FI set mentioned in Bentley doesn't have this "guide"?
Hardest part is getting the injector into the head, even one at a time. I found a socket about the same diameter as the distance between the metal "spring guide thingy" and used it to apply insertion force --- pretty awkward for those of us with big hands, but you can feel it "snap" into place. Rail went on nice and easy, without the lube.
Sounds like you got it done OK. As long as you were careful to not stress the rail by torquing slow and evenly.
Myke@RPI
Want to Buy - All Other Items (archive)
Jul 10, 2008 08:17 PM
Guest
Dec 23, 2007 11:40 AM
mistro
Mar 14, 2007 05:32 PM
gvoelker
Oct 5, 2006 10:17 AM
bolar
Mar 20, 2006 09:52 AM
