R50/53 VIS vs Seibon carbon fiber hood
Old Jan 2, 2019 | 03:49 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Insurance check finally came, ordering a new hood in the next few days. Anyone have experience with both and care to comment? They are basically the same price
Old Jan 4, 2019 | 01:55 PM
itchynscratchy's Avatar
itchynscratchy
I'm curious as well since i'll need a new hood and was thinking about going OEM. I've heard of fitment issues in the past with carbon hoods...not sure if that's still the case or whether it was related to both brands.
Old Jan 4, 2019 | 02:09 PM
They are both ok. Since they are handmade they can be a hair off from one to another and need a fine alignment or working with.
https://www.ecstuning.com/b-seibon-parts/v-mini/
Old Jan 28, 2019 | 06:36 AM
frozenbinary's Avatar
frozenbinary
Had some lady back into my hood recently, so i will be watching to see your thoughts.
new oem + paint + decals + blending = much more $$ than a carbon fiber hood.... it seems attractive on paper.
Old Jan 28, 2019 | 09:07 AM
Claviger's Avatar
Claviger
I worked for a carbon composite company which transitioned to aerospace exclusivly and closed their automotive department.
The VIS and Seibon hoods are hit and miss, some look fantastic, some have air bubbles throughout, distorted carbon pattern, or are over saturated and have wavy carbon as a result.
Regarding fitment, every car is shaped slightly differently. A few, rare times, they'll go straight on and line up. Expect to adjust hood mounting points, bump stops, and the latch at a minimum when aligning body line gaps. Some of the VIS hoods I've seen have been so bad they couldn't be made to fit even with bumper and fender mount adjustments.
ALL carbon should be coated with Urethane clear. The only exception are those built with Marine grade UV protected gel coat as their exterior layer (none of the Chinese companies do).
Not trying to scare you away, they look great. Just want to inform expectations.
Old Jan 28, 2019 | 02:41 PM
MrBlah's Avatar
MrBlah
I went VIS, have not installed it yet I'm in the middle of a clutch job
Old Feb 9, 2019 | 03:38 PM
400mphpc's Avatar
400mphpc
please post a few pictures once you get it mounted. I’m interested in your experience as well.
Old Feb 11, 2019 | 06:20 AM
Aabaco_R53's Avatar
Aabaco_R53
I’ve had experience with both. The SEIBON stuff seems to be stronger and fit a little better and VIS needed a little massaging to work and I have to redo the clear coat afterwards.
Old Feb 23, 2019 | 04:36 PM
MrBlah's Avatar
MrBlah
hood is on, just waiting on clips for the fender. I had no major fitment issues, I had to enlarge 2 holes for the drivers side headlight top mount posts but that was it
Old Dec 25, 2019 | 11:24 PM
jk6672's Avatar
jk6672
Could you guys post some photos of your hoods on? Anyone try Seibon doors or hatch?
eagle-co94
Dec 3, 2011 08:49 AM
robino
Dec 26, 2008 04:32 PM
FastLaneTuning
Jun 7, 2008 01:08 AM
