R50/53 I noticed a difference in the door card arm rest pads
Old Dec 31, 2018 | 02:33 PM
A383Wing's Avatar
A383Wing
I have a pair of MINI's......a 2004 R53 (mfg 10-7-2003).......and a 2006 R52 JCW (mfg 9-13-2006)
I noticed that the door arm rest pads are different lengths.....is this normal, or did someone switch door pads or door cards? Can I put the longer style on the older car without too much trouble?
First pic is 2004 R53 car, second pic is 2006 R52 car
Bryan
Old Dec 31, 2018 | 05:01 PM
RB-MINI's Avatar
RB-MINI
The longer pads are normal for the facelift MINI’s. I don’t think you can switch pads as the way they attach is different, but you should be able to switch the entire door panels. Since you have both I would try it before buying a FL set.
Old Jan 2, 2019 | 07:45 PM
JupiterR53's Avatar
JupiterR53
Hey, when you're removing the door panels to attempt the swap, can you look and see if the lower speaker grills are removable, or if the whole door panel needs to be purchased? My car had the speaker grills ripped out of the door, and it looks terrible... I'd like to replace them, but don't want to buy entire panels if I don't need to.
Old Jan 2, 2019 | 08:13 PM
Tgriffithjr's Avatar
Tgriffithjr
The grills are not removal. You might be able to find some and reattach them somehow otherwise you have to replace the entire panel.
Old Jan 3, 2019 | 10:08 AM
rkw's Avatar
rkw
You can buy speaker grills separately. The part numbers are here: http://www.realoem.com/bmw/enUS/showparts?id=RE33-USA-01-2006-R53-Mini-Cooper_S&diagId=51_5998. Purchase from a dealer or online parts vendor (Google the part numbers you want).
minikart4me
May 3, 2008 08:27 PM
latte hiatus
Mar 17, 2006 05:48 AM
GRENDEL
Apr 6, 2004 07:58 AM
Bobbyn
Jan 10, 2004 06:21 PM
