R60 how to remove Nav screen
Old Dec 26, 2018 | 06:58 AM
Hubie212's Avatar
Hubie212
installing a rear camera on my R60 Countryman, anyone know the best way to remove the nav screen ?
Old Dec 26, 2018 | 07:31 AM
dmath's Avatar
dmath
This doesn't show a lot of detail for the removal but it might be helpful:
Old Dec 26, 2018 | 07:44 AM
Hubie212's Avatar
Hubie212
thanks, there are numerous videos on YouTube , but none of them show removal of the screen
Old Dec 26, 2018 | 08:26 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.newtis.info/tisv2/a/en/r60-cooper-s-all4-sav/repair-manuals/62-instruments/62-11-instrument-cluster/IBHSVUt
Old Dec 26, 2018 | 08:34 AM
Hubie212's Avatar
Hubie212
does the trim ring around the screen just pop off ?
Old Dec 26, 2018 | 08:47 AM
Minnie.the.Moocher
Has a link in those directions top right for how to remove cover.
Old Dec 26, 2018 | 11:19 AM
dmath's Avatar
dmath
I thought that one did show removal of the screen -- now I understand what you meant. Glad someone was able to help.
Old Feb 6, 2019 | 10:40 AM
Steve500's Avatar
Steve500
Yes it does. But there is a secondary piece that must come off after that in order to remove the whole display unit. The top center vent needs to be removed which is done by removing the ambient light senor cover, pop the light sensor out, The display is very likely attached to the CD Drive unit just like the non-nav model's giant speedometer is and can only be unattached by removing both the display unit and drive unit at the same time which requires removal of the center console area. It gets nasty, lol.
Old Mar 24, 2019 | 01:28 PM
Chilli Pepper's Avatar
Chilli Pepper
Yes, Just used retainer remover tools. Start from bottom, on side , mickey mouse ears, and ontop.
Clip positions.
Bottom clip on both side.
Clip on the side both side.
Metal clip on dash board.
Clip on mickey mouse ears both side.
Two metal clip ontop and becareful for plastic bar in red circle.
Plastic bar came off from this small hole and becareful for wiring. That it.
Old May 3, 2019 | 11:14 PM
Alpha Motoring's Avatar
Alpha Motoring
Yes, there are no screws on the outer bezel, just pull towards you and it’ll pop off. Remove all the screws you see under it and the screen will come off with the speedometer.
Old May 3, 2019 | 11:15 PM
Alpha Motoring
Not attached to CD drive with a ribbon cable like non nav cars. Just simple wires to unplug.
Old Jun 6, 2020 | 04:47 PM
jimozach's Avatar
jimozach
Hi, newb here. I have a 2013 R60 All4. I'm putting in an aftermarket android unit, here if you care to see: https://www.aliexpress.com/item/4000401057977.html I have the mickey ears and the center vent off, but I need help with the panel that covers the CD and various controls. I have take out the three torx on either side, but I'm not sure where the rest are.I have a set of pry bars but I don't want to start doing it *****-nilly and break stuff. I have hunted high and low on the web to no avail...many instructions and videos but not for my exact model. I would be grateful if someone who knows more than me (that would be anyone reading this post) could help a brutha out. I'm expecting delivery in a few days, would like to be ready. Thanks in advance.
Old Jun 8, 2020 | 08:49 PM
navwizard's Avatar
navwizard
Check this out!
https://www.newtis.info/tisv2/a/en/r...dunit/EA77a9G2
Old Jun 9, 2020 | 04:33 AM
jimozach's Avatar
jimozach
Originally Posted by navwizard
Perfect, this is what I needed, thanks!
Old Jan 9, 2021 | 08:45 AM
Its Brittany B!tshh's Avatar
Its Brittany B!tshh
Here’s a video from beginning to end
Old Dec 27, 2021 | 08:10 AM
stiksandstones's Avatar
stiksandstones
Originally Posted by Its Brittany B!tshh
I notice in your vid-there is no issue with this nightmare 'airbag' situation? how did you avoid that area?
Old Dec 27, 2021 | 08:04 PM
MReiland's Avatar
MReiland
I believe the early R60's didn't have the knee airbag thus mot shown or mentioned in some videos. You'll know if yours has it if you look closely at the plastic piece under the glove box, it will be embossed with airbag if you have one
Old Dec 29, 2021 | 06:31 PM
navwizard's Avatar
navwizard
I noticed it looks like you connected the camera to 12 volt acc out. There should be a "rear camera" wire you connect to.
Old Dec 29, 2021 | 06:35 PM
stiksandstones
Yeah, I ended up switching it to that REAR CAMERA wire, and it all worked.
Old Jan 9, 2022 | 12:05 PM
stiksandstones
wrong thread
BoCRon
May 16, 2011 12:36 PM
JPMM
Jan 23, 2011 07:15 PM
ALS
Apr 2, 2008 01:36 AM
Marylander
22
Nov 8, 2007 01:18 PM
mdavis
Feb 19, 2004 04:09 PM
