JCW JCW owners running engine oil cooler?
Hello, how many of you are running an oil cooler? if the car is not tracked but driven through canyons and spirited driving does the R56 need an external cooler?
which cooler are you running?
IMHO - An oil cooler isn't necessary for street driving. There's no way you'll have the extended periods of full throttle that you'll experience on the track. Since there is an oil-water heat exchanger, running in Sport mode which drops the engine temperature to 180F will help keep oil temperature down.
Yes I track my car. No I don't have an oil cooler, but am considering one.
I suspect you already know the answer to your question. I drive daily over mountains and twisty roads at high speed and I don't feel my engine needs additional cooling. What you may need is better brakes if you don't already have the JCW set up.
If the oil temperature climbs to oh pick a number, 250F, or if oil pressure -- hot idle -- or at some higher RPM --- gets too low (what is too low? more on this below) an oil cooler might be a good thing. You want to be careful though that under less spirited usage the oil temperature is not kept too low. And you want to be sure if you install an oil cooler it does not materially affect oil pressure or flow. A really good oil cooler will flow oil (cold, warm or hot) without adding any real restriction.
Really the oil is at its sweet spot at 212F which is the temperature at what the high temperature viscosity index is determined. At 212F the oil is hot enough to boil out any water which is a good thing. Even oil up to 250F is not too hot but I would not expect the oil to get that hot in spirited driving. More likely it would get that hot maybe in around town driving.
For too low an oil pressure I don't know about my JCW but my Dodge Hellcat oil temperature can reach 230F -- just driving in town at moderate speeds even on a mild day (yet once on the freeway the oil temperature drops to after a few miles to around 185F even a bit lower) -- but oil pressure while it drops some from what it is at 212F is down just a few PSI to around 38psi when the oil is at 230F.
I would hazard a guess that say maybe half that would be considered too low although Dodge (or Mini) may have some spec somewhere that gives acceptable oil pressure numbers but I don't have this info. 'course, who knows at what oil pressure the low oil pressure warning light may come on? There is another concern for those engines that have piston oil jets. Usually these jets are fed through a pressure valve that closes if oil pressure falls too low. This is to ensure in low oil pressure situations the main/rod bearings get priority oil. The concern then is if the oil pressure is low while the oil pressure warning light may not be on the oil jet valve closes and the pistons are not receiving a nice stream of oil. At hot idle of a short duration this may not be a problem but ideally you want to ensure the oil pressure never drops that low.
Anyhow, my Porsche Turbo hot idle oil pressure would get down to around 1.5 bar but I do not know at what temperature the oil was.
For the oil pressure at high RPMs for my Porsche Boxster I don't recall the call out but for my 996 Turbo the oil pressure at 5000 RPMs and an oil temperature of 90C wanted to be approx. 6.5 bar or around 90psi.
I have no such info for my Hellcat but I do know watching my Hellcat's oil pressure at high RPM (>5K) I've seen 70+ PSI with the oil at around 212F. But it doesn't stay at 212F if the car is moving at a good clip. The oil temperature drops pretty quickly under these conditions.
I have a P3 MultiGage. Usual operation here in the desert is around 230F, +/- 5F. During MTTS 2018 I saw 247F-249F in the mountains. I talked with one of the support mechanics about the temperatures and he checked with someone on the engineering staff. What he found out out was that the synthetic oil they recommend breaks down at 275F. Obviously you don’t want to spend any time there, but it does give an idea of the safety factor involved.
On the N14 prince Peugeot R56, Does anyone know the hot and cold side of the aftermarket oil cooler engine adapters? For example, when facing the engine from the radiator side, there are two ports on the aftermarket adapter. Which is the output port ( left or right side) that carries the hot engine oil to the oil cooler radiator (the pre-cooled, hot side). Obviously the other left or right side would be the after oil cooler cooled oil port back to the engine? I realize I can find that out simply by touching or using infrared temperature sensor to both sides and note the temperature difference. I am trying to avoid the brute force 50/50 chance of getting it right the first time without having to reverse the hose connections, if I guessed wrong. Why, you may ask? Because I am installing a Inline Flow Series Motor Sport remote oil thermostat, FSM-215, by Improved Racing Products, so that my oil temperature will remain at optimum temperature of 220 degrees F.
Dennis Bratland
Sep 12, 2016 04:44 PM
kenshin
Feb 15, 2011 07:57 AM
