R50/53 Service mode 2
Old Dec 25, 2018 | 01:13 PM
jk6672's Avatar
jk6672
Service mode 2
I started off changing the crank pulley, idle pulley, 15% WMW sc pulley, wheel bearings, KW v2 coilovefs, Vorshlag Camber Plates, front and rear sway bars, bushings, and other miscellaneous items, but I figure while I’m at it I might as well replace the clutch and service or replace supercharger.
I was recommended the South bend stage 2 daily kit as an upgrade. Any experience with this kit? Also, with 116k miles how can I tell if servicing the sc is good enough or replacing it will be the better option?
Im going a little overboard and plan on powder coating the subframe so once this is all said and done I only want to do this once. I’m going to clean it up as much as I can and want to replace all that I need to while I’m at it. With the mileage what else should I replace so I don have to do this again for a while?
the only bad part of this project is not being able to drive the mini.
Old Dec 25, 2018 | 04:01 PM
ThumpR52's Avatar
ThumpR52
The Valeo Clutch kit is a pretty good bang for the buck. ModMini talks about it in one of his vids as it handled his 240 WHP without problems. If you think you need the 295 lbs of torque that the Stage 2 can take on your Gen1, then go for it. Its only money.
On the supercharger, what is your budget and how long you plan on keeping the car? Me, I would check to see how much oil remains. If you are really low then chances are the seals are going, if the oil level is good then change it and put it back on (you already have the thing off so doing the oil change is not that much more money).
Old Dec 25, 2018 | 06:16 PM
jk6672's Avatar
jk6672
The only way I’ll get rid of it is accident or I die. I really don’t have a budget, and dont mind spending the money. I like projects and they keep me busy. I’ll check the oil level first and go from there. I even want to ditch the JCW exhaust since it’s the original I am after more power. The plan is to fix it up now and then start saving for a upgraded built engine.
Old Dec 25, 2018 | 06:28 PM
ThumpR52's Avatar
ThumpR52
The JCW is a very good exhaust. The thing with exhausts and engine mods is making sure the engine is tuned to take advantage of what you have. IMO the tune should be done with a dyno or with logs such as the route that ByteTronik takes. A canned tune can adjust injectors and a little bit for a cam but you need A/F info to get more and then EGTs would even be better.
Modding a car is like buying a boat, both are holes that you throw money down into. In that aspect I am stupid as I continue to tweak my car.
Old Dec 25, 2018 | 06:41 PM
jk6672's Avatar
jk6672
I must be dumb as a rock then, because I’ve never had a car that I didn’t mod. My daily is a 100k + Cummins powered 3500 that I abuse in the desert.
Old Dec 26, 2018 | 08:04 AM
cooper48's Avatar
cooper48
The supercharger is pretty much bulletproof (there are very few working parts). When I bought my 2004 MC40 with 125,000 miles, it had never been touched. When I pulled the SC, one of the oil reservoirs (smaller of the two) was completely empty (but emitting no worrisome sound). How long it was empty who knows? I would be more concerned if it was the gear side reservoir that was empty so I just swapped out the oil and reinstalled it - runs fine. SCs are like cars -- you can spend just about any amount of money for a new one. Even a rebuilt model can set you back a coupla thousand. Just like cars of your youth, you're going to get more performance bang for the buck via head/cam/exhaust mods.
Old Jan 3, 2019 | 06:25 PM
jk6672's Avatar
jk6672
The fun began today, I had to force myself to start because it was mid 30's this morning. This is going to take me a while to complete as I'm having parts powder coated along the way and the parts list keeps growing. This is the first time I've taken it apart, I hope I don't have any extra bolts leftover when I've re-assembled it, lol.
Old Jan 3, 2019 | 06:33 PM
cooper48's Avatar
cooper48
Ha! Be sure to bag & tag. I used Ziplock freezer bags and a Sharpie to ensure that I knew what/where all the bits were. I have to admit I ended up with one small screw that I could never figure out.
Old Jan 3, 2019 | 06:42 PM
jk6672's Avatar
jk6672
for sure, grabbed the box of zip locks from the kitchen and before I could get out the door, my wife is telling me to buy more, lol
Old Jan 3, 2019 | 10:26 PM
jk6672's Avatar
jk6672
Are there any tutorials out there on how to replace the timing chain?
Old Jan 4, 2019 | 08:40 PM
jk6672's Avatar
jk6672
I was able to pull the super charger off today and drain the oil. I got about 90oz out of the pulley side and not much out of the water pump side. I also dropped off the intercooler tubes and clamps at the powder coat shop, I'm going to have them coated gloss black and the clamps orange.
I didn't have any problems with the water pump, but I'm going to replace it too while I'm at it since it's the original one with 117K. I've only driven it about few thousand miles and the only think I've had work on was the suspension and hubs, but while I'm in service mode I'd like to knock out a few things. I've been trying to find a video on changing the timing chain, but not really anything floating around that I found. Heck I'm not even sure if I should attempt to tackle it as it hasn't been a problem yet. I was thinking of just taking the cover off and seeing how the timing chain guides look because from what I understand the fixed guide is the one that breaks.
How many miles do fuel injectors last? should I think about changing them too? I have the JCW package on my 04, can I tell what size injectors I have by visually looking at them?
Sucks not being able to drive it, and this may sound crazy, but I'm rather enjoying my time working on it. Besides fixing up my diesel a little, I haven't really worked on a vehicle where I disassembled it this much since my 69 Bronco.
ahmedalsurmi
Sep 25, 2023 04:49 AM
hp79
Nov 29, 2018 05:27 AM
brandenash1
R55 :: Clubman Talk (2008+)
Jan 23, 2012 04:54 AM
tornado
Navigation/Audio
Jul 18, 2011 06:58 AM
fishbulb
Jun 19, 2009 07:42 PM
