R50/53 More Scan Tool Questions
Old Dec 23, 2018 | 07:19 PM
speedman's Avatar
speedman
I have looked at so many posts about P2096 codes my head is going to be explode. Can anyone tell me with confidence that they were able to clear this hard code without going to the stealer-ship. If you cleared it what scan tool was used. Thanks
Old Dec 23, 2018 | 09:04 PM
Zsm's Avatar
Zsm
Did use a generic OBD tool to read /erase to no avail. Replaced upstream O2 sensor after triple checking for vacuum leaks, faulty MAP sensors, and exhaust leaks.
After replacing the O2 sensor, it took about 3 days of drive cycles and P2096 was gone for good.
edit: if your car has the original sensors, it could not hurt to replace them. If not mileage, age can make the sensor suspect.
Old Dec 24, 2018 | 05:13 AM
speedman's Avatar
speedman
I ordered the O2 sensors and will put them on during the holidays
Old Dec 24, 2018 | 07:57 AM
Zsm's Avatar
Zsm
Hope that works. I’m guessing that you already checked everything else?
The only consistent brand of sensor to get is NTK. All others do not have the success rate of what MINI put in originally.
Old Dec 24, 2018 | 01:19 PM
speedman's Avatar
speedman
The code came on 6 months ago and went off after a week. Returned a few weeks later. I have monitored the O2 sensor voltage for the upstream and down stream. When the car is up to temp the upstream voltages oscillates from .1 to .9 volts but the downstream voltage is mostly flatline. It does fluctuate once in a while
Old Dec 24, 2018 | 01:31 PM
Zsm's Avatar
Zsm
That’s pretty consistent with what the two sensors should be doing. Upstream fluctuations correspond to fuel trim adjustment. Downstream is less active. Essentially, same as what I’m seeing on my kid’s R53 and my BMW E46.
Not sure if you saw this site. Some troubleshooting for. P2096:
http://bestride.com/engine-trouble-codes/P2096
Dec 12, 2018 03:33 PM
scatpack
Jan 10, 2016 09:43 AM
Brian425
May 30, 2012 12:17 PM
