R50/53 Arch trim problem
Old Dec 22, 2018 | 07:26 AM
Acurtis's Avatar
Acurtis
Arch trim problem
When I bought my 2005 S I lost the drivers side wheel Arch trim . I ordered the cheap one off e bay and it didn't fit right. This is the one on the hood. I found one off a junker that was the original one had tgt nut and bolt on the first mounting point. Fits the same way. It does not fit at thefendr too low about a 1/4" lower than the fender . What gives? Thanks for any help.
Old Dec 23, 2018 | 06:28 AM
Tgriffithjr's Avatar
Tgriffithjr
Pic maybe? Would help.
Old Dec 23, 2018 | 06:54 AM
Acurtis's Avatar
Acurtis
I can,t seem to go through the process of getting a new pic off my Android phone. Sorry
Old Dec 23, 2018 | 03:03 PM
Tgriffithjr
It will be hard to help without actually seeing where the problem lies. Is it the section at the top of the hood or at the bottom near the bumper? 1/4 inch is not much. Can you bend it into position? Has the car been in a fender bender that may have been repaired incorrectly? I know from experience that after market body parts, especially the cheap ones, don’t always line up correctly.
Old Dec 23, 2018 | 03:21 PM
Acurtis's Avatar
Acurtis
This is the problem . The hood lines up well no sign of body damage. I got this trim off a junker it is original. The one that fell off the car did line up well. Not sure what's going on.
Old Dec 23, 2018 | 03:38 PM
Tgriffithjr
Was the junked wrecked in the area where the trim was? If trim gets distorted and stays in that position for a while it can take on a set that is hard to remove. Could be you just got a bad trim that isn’t correct. Have you tried forcing it into position?
Old Dec 23, 2018 | 03:51 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
Are all of the clips intact? MINI sells the clips at a reasonable price. Attach the clips to the fender, line everything up, and push it into place!
Old Dec 23, 2018 | 04:14 PM
Acurtis's Avatar
Acurtis
I did get new clips. I have two fender Arch trim. Both fit the same way . I almost lost the other side. I used new clips on that and no problem , lined up perfect. The clips go into the trim and tthe trim snaps into the fender. Thanks
Old Dec 23, 2018 | 04:44 PM
Tgriffithjr
Well it’s definitely not all the way in place. Maybe taking it off and lining it up without clips to see if it will line up properly before putting the clips in place. Sort of a dry run. If it lines up without clips it should go on with them in place. That’s about all I can offer without being there. You never know what you get when you get parts off a junker.
Old Dec 24, 2018 | 03:45 AM
Acurtis's Avatar
Acurtis
I was hoping someone else had this problem. That's why I posted. At some point I'll get a OEM parts and see if that works. Thanks for all your help. A Curtis
Sin MINI
Dec 28, 2007 01:34 PM
roofaS
Jul 16, 2007 04:58 PM
fozworth
Oct 22, 2006 11:25 AM
atn57
Apr 1, 2004 09:56 PM
OctaneGuy
Nov 6, 2003 02:32 PM
