R50/53 Virginia help needed
Old Dec 16, 2018 | 02:07 AM
speedman's Avatar
speedman
Would anyone in the Richmond Va area have a code reader capable of clearing a P2096 code.
Old Nov 22, 2019 | 09:47 AM
speedman's Avatar
speedman
If you do can you tell me what type of code reader are you using
Old Nov 22, 2019 | 09:59 PM
adriancl's Avatar
adriancl
There are two types of errors , stored fault codes and permanent fault codes.None code reader can erase a permanent fault code.You must remove the mechanical or electrical issue first of all, and after that your code reader will be able to erase fault code.On R53, a stored fault code does not cause MIL on, after engine restart if fault code is only stored, MIL is off.Only Airbag faults , even are stored faults need a code reader to erase.
Old Nov 23, 2019 | 08:36 AM
speedman's Avatar
speedman
I thought that once a hard or permanent code was set it had to reset with a programmer even after the problem is corrected in the case of a P1498 code it is for long term fuel trim. It measures current and compares it to stored data, right. If what you have told means that I still have a problem
Old Mar 3, 2020 | 09:51 AM
speedman's Avatar
speedman
Still looking for some help with this code
Old Mar 3, 2020 | 12:33 PM
Derek86's Avatar
Derek86
Over a year? That's no joke dude.
If you have a smartphone you can get a bluetooth OBDII plug cheap-ish on Amazon. You can read and clear some codes with free and paid software.
Old Mar 3, 2020 | 06:30 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Do you have modifications ? If so that error will happen no matter if it's running perfect or not sometimes . I HAD to have it tuned out. Adriancl did it for me. You could always ask him and I could borrow you my computer to obd2 connector I used too .
the elm327 and any scanner no matter what would not erase that code and no matter what sensors or what were replaced the code stayed present until tuned out.
Indie
12
Feb 24, 2015 05:33 PM
ShaLor
Dec 12, 2012 05:24 PM
Big Daddy
Oct 26, 2006 01:34 PM
agile_moments
Oct 20, 2005 06:48 PM
