R60 R60 new owner - Double DIN solution (maybe)
Old Dec 10, 2018 | 12:56 PM
GTRik's Avatar
GTRik
Hi All,
Rik from Calgary, Alberta, Canada. Close to a new (to me) Countryman owner, and have been doing some research into the Double Din headache, when looking to add to the Countryman center console. I've been playing in photoshop, and have carefully scaled the META Double Din bezel, so that it fits the Countryman profile. Although this would mean a "kitbash (scale model term)", it looks like it may be possible to graft the META into the stock Countryman. This is hypothetical, but by removing what looks like the thin cubby (remember, I am in the process of purchasing), everything might be able to shimmy down.
Now a question to existing R60 owners who have dared open that console... is there enough room?
Curious to get feedback.
Rik
Possible R60 META to stock console solution?
Old Dec 11, 2018 | 08:49 AM
scf's Avatar
scf
There's a support structure behind that facia too.
Old Dec 11, 2018 | 01:37 PM
finny70's Avatar
finny70
I found this recently, someone has done it
Old Dec 20, 2018 | 09:31 AM
supazuk's Avatar
supazuk
there is a kit but not a fan of it as I don't want to lose my big speed o https://www.spiralaudio.com/index.ph...roduct_id=1009
Old Dec 20, 2018 | 09:58 AM
finny70's Avatar
finny70
thats for the later F series models
Old Dec 20, 2018 | 08:04 PM
supazuk's Avatar
supazuk
Countryman (2014-UP)
nope just the 2014 up r60
Old Dec 20, 2018 | 10:40 PM
finny70's Avatar
finny70
it even says COUNTRYMAN 17 UP in the advert if that helps?, all the minis quoted are F series, The countryman from 2010 until F series has the same dash, my cm is a 12 and I have the 14 black dash parts fitted and also if you look at the picture you can see the hazard light switch in the F series position, it does say HARDTOP 14 UP which is a F series again.
Scroll down the page to the compatability list not the header that is rather vague.
Old Dec 22, 2018 | 04:43 PM
supazuk's Avatar
supazuk
i see that now either way dumb setup
Old Dec 23, 2018 | 12:17 AM
finny70's Avatar
finny70
That dumb set up is MINIs set up now, that part on the F series is no longer the speedo you so like on your R series, that part is just allowing you to fit your own system other than mini fit, there are however android head units incorporating a speedo for the R series on the market.
DMancini
Apr 20, 2018 07:02 AM
1atom12
Jun 25, 2010 01:54 PM
rigidjunkie
Mid-Ohio Motoring Club
16
Mar 4, 2010 02:22 PM
Nuff
Apr 15, 2006 09:47 AM
CustomAV
Mar 27, 2006 09:28 PM
