Concerning Engine Buzzing in new to me N18 R56s
Old Dec 7, 2018 | 04:56 AM
FRlSKY's Avatar
FRlSKY
long time lurker, first time poster.
I recently took the plunge and picked up a 2013 R56s N18 with 30k miles, well maintained by an older owner for a solid price. Regular frequent oil changes. Aside from having to replace an ignition coil and swapping tires/ needing alignment, a concerning sound has started occurring which I need the forums help with.
It started one morning and hasn’t gone away. It is a high pitched metallic kind of grinding sound, which is directly linked to acceleration and deceleration. It does not occur in neutral when coasting. It gets more prominent as I accelerate . It’s very prominent with the windows up and sounds like it’s coming from the front right of the car. I still have full boost.
I’m worried that this is the turbo prop grinding against the wall. To be clear, I know there is a turbo whine that comes with the R56s which it used to have and this is not it.
I apologize for the quality in video, for some reason the iPhone isn’t picking up the pitch very well, but it can still be heard.
Old Dec 13, 2018 | 06:59 AM
S-2013's Avatar
S-2013
Auto or manual? Also could be something to do with the serpentine belt like the pinch roller.
Old Dec 13, 2018 | 02:11 PM
FRlSKY's Avatar
FRlSKY
It’s a manual
Old Dec 13, 2018 | 02:59 PM
RockC's Avatar
RockC
Agree. Hard to believe a turbo charger could be the source of the noise and yet still deliver boost or even still remain together. The turbine/compressor spins at some ungodly high revs, in some cars around 70K RPMs. Even cutting this in half to 35K RPMs if there was any contact at all by the spinning turbo charger hardware with its housing I think the turbo would be in pieces, and some of these in the engine, by now.
With a turbo charged car (not a Mini) with 2 turbos over 161K miles I had to replace two serpentine belt idler rollers (the bearings) due to the bearing getting noisy. One time the bad idler roller bearing emitting a "dry bearing" sound. The 2nd time I could hear an intermittent/sporadic high pitched "chirp". Also, with other cars none of which were Minis, I've replaced more water pumps (2) than turbo chargers/super chargers (0).
Old Dec 14, 2018 | 06:37 AM
thefarside's Avatar
thefarside
30K miles/5 years of service is an unlikely combination to cause an accessory or axle bearing to fail. Another reason to discount bearing failure is that the noise is eliminated by coasting.
My first vote would be the torque arm on the bottom of the engine.
Try coasting in neutral, rev the engine hard and also gently, report the results.
Another possible culprit; the engine mounts, but given the age of the car not very likely.
Old Dec 14, 2018 | 01:04 PM
FRlSKY's Avatar
FRlSKY
So it makes the same sound regardless of standing still reving, moving and reving in neutral or in gear. It is directly toe and step linked to the acceleration and doesn’t really vary from day to day or the warmer/ colder it is outside.
Old Dec 15, 2018 | 03:38 AM
thefarside's Avatar
thefarside
Remove the serpentine belt and run the engine briefly since the water pump is not running. Do this when the motor is warm. If the racket continues then find a good tech.
Also, get a new belt since the odds are good that it needs replacing anyway, and get either the Mini or an EPDM one, not a cheap aftermarket.
randyeby
May 3, 2013 08:59 AM
Gif
Detailing 101
24
Jun 30, 2007 11:08 AM
rbgoforit
Jun 7, 2006 10:05 AM
Smokey
Jun 30, 2004 06:48 PM
Yucca Patrol
Site Feedback
Feb 1, 2003 02:25 AM
