2012 R56 Rough running
Old Dec 5, 2018 | 11:09 AM
TonySyn's Avatar
TonySyn
Hi Guys,
Right, I have a problem that I can't seem to solve. Basically, my Check engine light came on with a loss of power, so I checked the codes and it was indicating that the thermostat sensor was out. So I replaced it and the oil sensor too, but still the same. So I changed out the coils and it started to not run rough. Great, however, the light is back on now and its feels like the turbo isn't responding, whether this is due to the fault or not, it just doesn't seem like a turbo fault.
The codes are as follows;
DTC
2774 CAN message,, engine shutdown time.
00, 01, 2C, 57 No found
00, 01, 29, 05, No found.
If I erase the codes, it runs ok, until I go to give it some power, then the CE light is on again and it is back where we started.
Its a 2012 R56, N18 motor with 80k miles
Any ideas, anyone had something similar, I ask because it is just trowing out codes that don't seem related to the actual problem, I mean why give me a coolant error when its actually the coils, makes no sense...
Thanks in advance guys, appreciated
Old Dec 9, 2018 | 05:22 AM
MiniToBe's Avatar
MiniToBe
I found this for you. It might be a good start.
http://forums.pelicanparts.com/mini-...code-2c57.html
Loomie
Jul 5, 2016 10:41 AM
brianj
Mar 16, 2014 01:46 PM
agarnsey0540
Factory JCW Talk (2009+)
Feb 17, 2010 04:48 PM
Couille
Classic Mini Talk
Jul 4, 2006 09:13 PM
