Turbo failure?
Old Dec 4, 2018 | 07:24 PM
Neil Franklin's Avatar
Neil Franklin
Turbo failure?
Just replaced my hpfp on my 09 cooper S which I had all the symptoms saying it was bad that issues fixed but now I’m only hitting 5psi max at wide open throttle, I hear it spool up to 5 then die down, bit of burning oil smell too I’m thinking failed turbo seals but figured I’d ask if anyone else has ideas
Old Dec 4, 2018 | 08:08 PM
E34M5's Avatar
E34M5
Did you have the problem before you did the hpfp? did you scan it any codes? you may have a turbo air leak, did you knock off one of the pipes by accident when doing the hpfp?
Old Dec 4, 2018 | 08:23 PM
Neil Franklin
Burning oil smell was there but was running normal boost before doing the hpfp everything is still on and tight with no codes
Old Dec 4, 2018 | 08:53 PM
NeonLed's Avatar
NeonLed
Check the vacuum line going to the wastegate. Sounds like the gate might be stuck open.
Old Dec 6, 2018 | 01:06 PM
Neil Franklin
yup vacuum line was on but not all the way down running good now👍🏻
Old Dec 10, 2018 | 10:31 PM
sawicki's Avatar
sawicki
Check the intake pipe that goes from the Intake to the turbo. After i did my HPFP mine kept blowing off and ended up having to replace the Hose
Old Dec 12, 2018 | 08:17 AM
They like to wiggle off or crack then work there way off:
https://www.northamericanmotoring.co...rbo-inlet.html
DomesticMuscle
Factory JCW Talk (2009+)
Nov 22, 2013 08:46 AM
67-LS1
Sep 21, 2012 09:37 PM
redbullfx2
Dec 5, 2011 06:24 AM
leomulhollandiii
Jul 1, 2011 09:10 PM
OttomanFD3S
Apr 28, 2011 08:48 PM
