R50/53 Turn signal help
Old Dec 3, 2018 | 03:54 PM
Chicothe1's Avatar
Chicothe1
Turn signal help
I have a very unique problem with my turn signals. I say unique because I cannot find a thread that has been able to help. The right side of my turn signals work but not the left. None of the left turn signals work. All brake lights and reverse lights work fine but none of the turn signals on the left work. Not the back side or front. Please help! Closest solution I could find is the ECM needing replaced. I am new to minis and love it so far just want to figure this out.
Old Dec 3, 2018 | 04:51 PM
Tgriffithjr's Avatar
Tgriffithjr
Turn signal switch bad?
Old Dec 3, 2018 | 04:54 PM
Chicothe1's Avatar
Chicothe1
Turn signal switch
Is this the switch that others are talking about in the steering column? I check the voltage for the turn signals at all three spots while it was “turned on” with no power going to it. It the switch would turn on the voltage to the turn signals when activated then you could be right.
Old Dec 4, 2018 | 05:20 AM
Tgriffithjr
Yes the switch distributed power to the turn signals.
Old Dec 4, 2018 | 07:03 AM
Chicothe1's Avatar
Chicothe1
Maybe a different twist on things. The blinker light on the dash works at a normal speed when the blinkers don’t actually work. Could this still be the switch?
Old Dec 4, 2018 | 07:15 AM
Tgriffithjr
Check your wiring to the left side from the switch. Sounds like a break somewhere. Try turning the hazard light switch on and off a few times. The hazard switch can be defective and break the connection to the turn signal switch.
Old Dec 4, 2018 | 07:32 AM
Chicothe1's Avatar
Chicothe1
The hazard lights are the same way. Only the right side of the car works.
Old Dec 4, 2018 | 07:44 AM
Tgriffithjr
Well it is still possible that the hazard switch is the problem. Otherwise you will need to trace power to the switch and back out to find where the disconnect is.
Old Oct 29, 2021 | 04:36 PM
Hemi qwer's Avatar
Hemi qwer
I'm having the same problem.
Old Oct 29, 2021 | 04:43 PM
Hemi qwer's Avatar
Hemi qwer
More signal problems... No signals on left as well as low beam and break light.. Plea
Old May 24, 2024 | 03:01 PM
Rhinebolt's Avatar
Rhinebolt
I have the same issue e problem
Bought a new switch and still have the issue
gob15
Oct 14, 2018 02:30 AM
Sigboi
Oct 2, 2016 11:21 AM
tgr4tgr
May 14, 2014 06:49 AM
MalloryJade
Feb 7, 2011 06:10 PM
Checkmate_2006
Jan 11, 2011 05:43 PM
