oil around the supercharger- how to fix?
Old Nov 30, 2018 | 07:19 PM
RudeJoe's Avatar
RudeJoe
I've been watching oil start to accumulate on the supercharger. Any idea what's causing this and how to fix it?
TIA!
Old Dec 13, 2018 | 02:50 AM
RudeJoe's Avatar
RudeJoe
Any help? Thanks
Old Dec 13, 2018 | 04:58 AM
Tgriffithjr's Avatar
Tgriffithjr
Could be an IC boot leak? If you have removed the IC at some point it’s easy to not get the boot on properly and have it folded in on itself underneath where it’s hard to see.
Old Dec 13, 2018 | 07:07 AM
AoxoMoxoA's Avatar
AoxoMoxoA
I'm going to concur with Tgriffithjr on this one and go with improper installation or shifting of the poorly designed aftermarket intercooler boot.
There's really nowhere else in the area which would produce the oil you see on the intake manifold.
The left edge of your pictured intercooler boot should protrude from under the clamp (actually centered between the left & right clamp), thus providing the seal which would thwart oil blow-by. Yours does not, and the whole boot seems to be shifted to the right, therefore, no seal at left clamp. I've attached a pic of mine to illustrate my point.
Remove, clean up area, properly center boot, re-tighten clamps and observe over the coming days/weeks for new leaks.
I'd suggest you change to the OE boots, they really are the best option.
Old Dec 13, 2018 | 07:13 AM
Minibeagle's Avatar
Minibeagle
Aftremarket intercooler boots are a great way of wasting boost pressure. Take them off, degrease that mess and install oem boots.
Old Dec 13, 2018 | 07:36 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Yeah! But the OE boots are the boring black and the AM boots are bling neon colors and made of silicone (like the products for breast augmentation ) . I contemplated buying a set of low mileage OE boots as spares but so far I haven't found any, as the average mileage of gen 1 Mini's are around 100k (mileage not value in the mighty USD).
Old Dec 13, 2018 | 08:20 AM
Tgriffithjr
Ive never seen neon breast implants. Could be helpful in the dark.
Old Dec 13, 2018 | 07:48 PM
RudeJoe's Avatar
RudeJoe
The boots were on the car when I bought it. I did like the color though. I did take the IC off when I did some maintenance a while ago. Perhaps I didn't get it back on correctly or the boots are due for replacement. I'll take a look. Is there that much oil going through the IC? The car does have high mileage (210K+). Thanks
Old Dec 14, 2018 | 03:31 AM
Tgriffithjr
There is always oil present and over time a leak will accumulate.
Old Dec 14, 2018 | 06:10 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Oil vapor makes its way from the engine interior through the PCV valve (on valve cover) and into the supercharger, where it is compressed and forced at high volume to the intake manifold, then reintroduced into the engine along with fuel, and burned in the cylinders. If there's a leak in the pipeline along the way, such as a displaced or faulty intercooler boot, then yes, it will easily be forced out, creating the mess you see on your engine.
You are most likely deficient on boost pressure -- i.e., performance as well.
Old Dec 14, 2018 | 07:12 AM
Derek86's Avatar
Derek86
TIA!
So, before you buy any parts, clean up the mess and arranged your intercooler boots and clamps correctly. They both look incorrectly placed, and the silicone boot looks to be distorting/stretching on the right side. Then see if the oil comes back.
Mini_Chan
Dec 23, 2019 02:25 PM
martmanvan
Mar 29, 2018 05:26 AM
MinisWIthAttitude
Apr 22, 2016 04:05 PM
Bponce23
Aug 1, 2012 12:53 PM
Stevena613
May 1, 2012 08:20 AM
