Suspension R53 lowering problem? Coil rub
Old Nov 22, 2018 | 06:55 AM
Ottoman711's Avatar
Ottoman711
Hello all, new here. Recently installed raceland adjustable coilovers on my Mini. With the factory wheel tire combo it rubs on the front springs! I even put on a 10mm spacers and can't even drop the car lower than original height. OE wheels are 17x7 48 offset with 205/45s. If I add anymore space it will clear but rub on the wheel flares. Anyone had this issue? Somewhere a guy said he swapped out to a 16x9 15 offset and had no issue but I'm having a hard time believing that given the fact the wheel is 2 inches wider. I'm looking to tuck. Thanks and sorry if this is in the wrong thread.
Old Nov 22, 2018 | 02:26 PM
Gtech12v's Avatar
Gtech12v
I had the same problem fixed with 12" spacers
purchase on eBay
2 WHEEL HUBCENTRIC SPACERS JDM Honda Acura Mini Cooper 4X100MM 12MM 56.1MM
Old Nov 23, 2018 | 09:27 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Yep, space it out a few millimeters. Thats usually what needs to happen. That was the same for me too
Old Dec 5, 2018 | 02:19 PM
audihere's Avatar
audihere
I have 15mm spacers in front on mine. The KW V2 coilovers that WMW sells seems to have smaller diameter springs which could help clearance, but I'm not sure. Did you do an alignment? What's your camber set to?
ridinDirty
May 14, 2021 07:15 PM
EnormousMini
Feb 10, 2016 09:30 PM
freestylebiker33
Jun 9, 2013 07:27 PM
mamiller9
Apr 17, 2010 07:35 AM
ruggedbert
Suspension
Dec 9, 2005 04:14 PM
