R50/53 External automatic transmission cooler
Old Nov 11, 2018 | 05:27 PM
speedman's Avatar
speedman
Got a 2005 MCS with a 6 speed Asian transmission. I just re-built it and now I want to protect it.
Does anyone know if there is a company that makes an external cooler?
I am thinking about building a cooler system by installing an inlet and outlet in the existing transmission pan, in-line pump, cooler and temperature gauge. Any thoughts?
Old Nov 11, 2018 | 07:04 PM
Minidogger's Avatar
Minidogger
I have done one-off mods like this & found that there are usually flies in the ointment.
You will have to figure out how to support the hoses so the joint thru the pan doesn't fatigue or have some crazy harmonic frequency. Then there is aeration to worry about. 2 things just off the top of my head.
If it was needed to make the tranny live, the OEM would have installed a cooler to protect against warranty failures.
Old Nov 11, 2018 | 07:39 PM
speedman's Avatar
speedman
But almost all Asian transmissions die because of the lifetime fill of transmission fluid. This would help
Dennis Bratland
Sep 12, 2016 04:44 PM
Thunder Tomato
Jan 30, 2014 01:37 PM
minivette
Aug 10, 2009 12:20 PM
