How to inspect / refill torque converter off car
Old Oct 18, 2018 | 02:24 PM
Noahl's Avatar
Noahl
I could not locate any post's on this, so I decided to ask the question. I am about to put in a low mileage used automatic transmission in a 2007, and wanted to know first off, do I use the converter that came with the used transmission? If so, is there any inspections I can do to ensure it is working properly? How do I flush this while off the car?
Any words of wisdom would be greatly appreciative.
Old Oct 18, 2018 | 03:10 PM
jglover's Avatar
jglover
Put a used automatic in my mini and used the converter that cam with it. The old on may have debris in it. I never drain it sense there is no dip stick. Put the amount of oil that came out, back in. Ran it for a little bit and then rechecked oil. Then sent to a mechanic and had him recheck the oil when it was on a lift, running. Flush is a matter of drain and refill. What you take out is what you put back in.
Old Oct 19, 2018 | 11:32 AM
Noahl's Avatar
Noahl
Thanks for the advise on the Fluid. Did you have to "reset" the Computer to re-learn the new transmission? I have been reading a few posts on this.
FrameDragger
Nov 3, 2023 10:31 PM
DianaUT06
Jan 7, 2017 06:35 PM
pal
Middle Georgia MINIs
Feb 24, 2013 08:15 PM
JPMM
South East - Florida
Jan 22, 2010 10:26 AM
wainair
Oct 10, 2002 10:12 AM
