Unstable idle at cold start on cold weather
Old Oct 5, 2018 | 07:52 AM
Theodor's Avatar
Theodor
Hello.... mini r56 non s with 120hp 59.000miles
I have got unstable idle at cold start on cold weather only (about 50 Fahrenheit or lower). And only for 20 seconds.
With no faulty codes or check engine light
New spark plugs & air filter and oil level ok
Never change vanos, only cleaned them.
Never change lamba sensors
any thoughts?
Old Oct 6, 2018 | 04:10 AM
Theodor's Avatar
Theodor
Any ideas?
Old Oct 10, 2018 | 09:56 PM
2cati's Avatar
2cati
I have a similar issue with my 2013.
Ill be trying bg44k.
Old Oct 10, 2018 | 11:29 PM
Theodor's Avatar
Theodor
This is a fuel system cleaner
How bg44 help? Where the problem spotted?
Fuel pump? Filter? Injection? Or somewhere else?
Mine is base, without direct injection....
So valves cleaned for injectors and there is no carbon on valves.
Old Oct 10, 2018 | 11:39 PM
2cati's Avatar
2cati
I’m not sure if it will address my issue but I’ll tell what I’m not going to do:
1. Let the dealer diagnose trial and error at my expense ...
my spark plugs, coils, battery were replaced in January by the dealer. Timing chain and tensioner are in perfect shape. I have almost the same mileage as your car.
Ive read a lot of reviews and I’m willing to try bd44k for 2 tank fulls.
This is the only issue with the car - rough idle for less than a minute when started cold.
I have no engine check light.
Im also going to start using shell 91 as it has zero alcohol.
Old Oct 10, 2018 | 11:52 PM
Theodor's Avatar
Theodor
The odd thing is that it only does it at a low temperature...
Perhaps the vanos solenoid is blamed because the oil is thicker, or even the lamda sensor, until the catalyst is warm!
no check engine or fault code too!
please let me know if bg44 fix the problem
thanks
Old Oct 24, 2018 | 12:17 PM
Theodor's Avatar
Theodor
Any news?
bg44 works?
Old Oct 24, 2018 | 02:56 PM
2cati's Avatar
2cati
Thanks for the reminder.
Ive gone through one tank of Shell 91 (zero ethanol) and a can of bg44k. I can’t say I’m seeing a material improvement. I’m now just started my second tAnk full and second can of Bg44k. I am driving the car harder in sport mode.
Will update if I see an improvement or the second tank is depleted.
will report back.
Old Nov 5, 2018 | 11:41 PM
Theodor's Avatar
Theodor
Hello 2cati....
Any news?
Old Nov 8, 2018 | 10:56 PM
2cati's Avatar
2cati
Sorry for the delayed response.
About 1/2 way through the 2nd tank with bg44 And again not noticing an improvement.
Old Nov 9, 2018 | 08:45 AM
I like mini clubman's's Avatar
There may be some others who can confirm this suggestion. I have a dodge ram that was acting strange on cold startups. Ran rough and terrible idle. I did everything I could at the time but was working 7 days a week and had just bought a new house. I took it to a neighbourhood repair shop to get fixed. They basicly gave up after changing a pile of parts. They suggested I take it to the dealer to have the computer flashed. I brought it home and disconeccted the battery overnight. That reset the fuel trims and it has been fine for four years. This is a simple try that's free, but I'm am not familiar enough with minis. They may or may not reset the fuel trims when the computer loses power. If its not the fuel trims it could be the HPFP from the hundreds of posts I've read here.
Old Nov 9, 2018 | 10:40 AM
58caddy's Avatar
58caddy
The non-S models don't have the HPFP if I'm not mistaken. I believe that is only on the S and JCW.
Old Nov 9, 2018 | 10:50 AM
Yep I missed the non s part at the start of the post. Next would be map sensor cleaning.
Old Jan 16, 2019 | 10:20 AM
GsxR1000's Avatar
GsxR1000
FWIW - I'd suggest replacing spark plugs and coils, if it has never been done.
Good luck,
Old Jan 16, 2019 | 10:27 AM
2cati's Avatar
2cati
Good luck,
Thank you....all coils spark plugs were replaced by MINI last January....
Old Jan 16, 2019 | 10:43 AM
Theodor's Avatar
Theodor
I changed 3 months ago both vanos solenoid, without any change at unstable idle.
I tried to clean the throttle body without getting it out ... only with a spray cleaner throttle body & carburettor
the idle has improved a lot, not completely, but in a percentage 80%.
it does make a minimum bounce now.
I will try it again and I hope fix it
Old Feb 18, 2020 | 02:21 PM
Theodor's Avatar
Theodor
I noticed that it does it on a smaller scale,even if it turns off for 2 hours.
When it's cold it's more intense, because high idle.
I recently changed all coils and the oxygen sensor before the catalyst without effect.
any ideas?
Old Oct 11, 2020 | 07:07 AM
2cati's Avatar
2cati
Recently I had the engine check light go in and I scanning the codes it seemed to be unrelated to the idle issue and the thermostat housing was replaced under warranty.
i also has some “tapping noise” the almost disappeared after putting in Risoline high mileage treatment in the oil (I was shocked it worked) but the surging on cold start is still there.
too bad as I really love the car (brilliant handling and style) so I’ve decided to sell it as it seems something will Always go wrong with the engine and electrics.
I’ll give the dealer a chance to diagnose it at my cost $150+tax to see what they come up with.
No CEL but I’ll will see if there are any codes since the thermostat change.
Slapshottr
Dec 18, 2018 02:07 PM
cudamank
Nov 2, 2018 11:40 AM
redlinealley
Oct 5, 2018 01:35 PM
alparmer
Jul 20, 2018 02:26 AM
Overboard769
Jan 1, 2018 08:56 AM
