Wallnut media Blast the intake
Old Oct 4, 2018 | 02:45 AM
drea-min's Avatar
drea-min
i just get done with Wallnut Media Blast on R55 Clubman S 100,000 miles on the car
Before and after..
Old Oct 4, 2018 | 02:48 AM
drea-min's Avatar
drea-min
After the Wallnut Media blasting
here is the results
i noticed there’s a line between the 2 intake valves.
Old Oct 4, 2018 | 06:32 AM
cornjuice's Avatar
cornjuice
1. omgwtf?
2. had this engine ever seen this service before?
3. did the car sound like it was breathing through a snorkel under water? That is some of the worst buildup ive seen on a mini before.
Old Oct 4, 2018 | 10:51 PM
drea-min's Avatar
drea-min
Intake valves
I was the third owner so i don’t know the history, the car runs fine though no CEL codes, a little rough idle during initial start-up other than that its fine. I read a lot of nasty issue about N14 engine especially direct injections so i decided to do it myself. I started the car and started fine, i haven’t drove it yet maybe tomorrow.
Old Oct 5, 2018 | 06:59 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Looks like you did a pretty darn good job. We do them all the time in our shop. You'll notice more power and better fuel mileage now.
Old Oct 5, 2018 | 02:07 PM
MrGrumpy's Avatar
MrGrumpy
Wow! Those were filthy! I’ll bet you notice a pretty significant improvement when you do drive it!
Old Oct 5, 2018 | 09:37 PM
Wildfield's Avatar
Wildfield
Great photos. Thanks for posting.
What year is your R55?
Old Oct 5, 2018 | 09:46 PM
drea-min's Avatar
drea-min
2008 Clubman S
yeah the car runs better no more engine shakes and shift even better now.
Old Oct 7, 2018 | 06:51 AM
DGI's Avatar
DGI
Awesome before and after!!!
I've been told that on the later N18 motors, carbon build up isnt so much an issue but i'll be monitoring it as I continue to drive.
Would have been neat to see before/after dyno numbers for fun!
Old Oct 7, 2018 | 10:20 AM
spicoliinkc's Avatar
spicoliinkc
I just finished up walnut blasting the intake valves on a 2010 clubman s. I have new coils and new plugs, I am still getting multiple misfires, mostly on the number 4 cylinder according to the scanner. Any help or suggestions would be greatly appreciated. Thank you
Old Oct 8, 2018 | 12:21 PM
Wildfield's Avatar
Wildfield
I've read the same thing. Still, I am curious if I am getting carbon build up. I have 77K miles on my 2013 R55. I'll have to figure out how to check for carbon build up.
I bought my 2013 used in 2016 with around 26K miles. After installing aftermarket water temp and oil pressure gauges, I noticed that it ran at around 220 degrees +/- 10 degrees. That seemed hot to me, so I asked a Mini tech if this was "normal". He said that in 2012 they increased the water temp of the R55 to 220 degrees, to help mitigate carbon build up. The same tech also recommended frequent oil changes even though I am using synthetic oil. I've gone this his recommendation and changed my syn oil every 5K miles.
Car runs pretty smoothly (knock on wood) but still curious to see if I have any carbon build up.
Old Oct 8, 2018 | 03:13 PM
MrGrumpy's Avatar
MrGrumpy
Yes 220F sounds right for the temp. I don’t think it actually does help much with the carbon issue, since so many folks out there (myself included) have had their ECU remapped and the coolant temp lowered. Anecdotal evidence would seem to suggest that it doesn’t make very much difference, but I don’t claim to be an authority on it. The changes that they made to the N18 appears to have done a lot to keep it at bay more so than with the N14 engines. I am almost 100% positive that the previous owner of my “Duncan” never had it done, as he kept meticulous records which I am now in possession of. I had the intake manifold off a week or so ago to replace the plastic water pipe back there underneath it. Since it was off I had to check them out.
So.....yes, they are dirty and probably in need of a good blasting. But keep in mind, this car has not had the valves blasted before. They are dirty, but with a little over 120K miles on it, I really expected them to look a whole lot worse than they do! So I guess I’ll be picking up a media blaster soon. Lol.
This was probably the worst looking pair
Old Oct 11, 2018 | 01:52 PM
minidd99's Avatar
minidd99
I am having the same multiple misfires on cylinders 3&4 and have changed plugs and coils.
Anyone know where I should start looking next???
I don't have an import shop close to me so taking it in is a major journey.
I only have basic tools and knowledge.
Don't know about extent of carbon build up, I have an N14 JCW engine with 55,000 miles
Not trying to hijack this thread.
Old Oct 11, 2018 | 03:45 PM
spicoliinkc
I was able to try out another high pressure fuel pump too thinking it could be the cause of the multiple misfires. It did not fix the issue, I've also replaced the cam position sensor as well. The only other thing I can think of is a possible injector.
Old Oct 11, 2018 | 04:55 PM
minidd99's Avatar
minidd99
I have switched plugs and coils from hole to hole now but still have 3&4 cylinder misfire codes.
Let me know how you make out and I will do the same.
I am thinking injectors also.
knarf444
Jan 25, 2016 06:23 AM
WannaMini_
Jun 2, 2014 11:54 PM
MINIHOLLAND
23
Feb 5, 2003 11:29 AM
Cooperman
Jan 18, 2003 03:36 AM
